Old 04-21-2004, 05:30 PM
kbarlettafran kbarlettafran is offline
HELP SES code P0141 not sure which O2 sensor to replace
My SES light showed up a few days ago on my '97 GT. I had a friend pull the code. He siad it was P0141. He said that is the O2 sensor that is on bank 1 sensor 2. Is he correct and if so which O2 sensor does the code correspond to and where it is located. I believe there are 3 sensors, SENSOR,HTD OXY(POSN 1) in the exh manifold, and 2 that are SENSOR,OXY(POSN 3) post manifold, is this correct? This is based on the acdelco part list. But I am not sure which I need to replace. Please help.
Thanks
FB
Old 04-21-2004, 06:53 PM
Flatrater's Avatar
Flatrater Flatrater is offline
Main GM Guy
Re: SES code P0141
Here is how the O2 sensor locations work.
Bank one is always the odd bank, bank 2 is the even bank.
Sensor one is the first one located closest to the engine, sensor 2 is the next one after sensor one. On most car engines with one manifold have only 2 sensors. One on the manifold is the engine management sensor and the other is after the cat which only monitors cat efficiency.
Bank one sensor 2 is the one mounted after the cat.
Shop Foreman Buick Pontiac and GMC dealership
ASE Master Tech
ASE Advanced L1
GM Master tech
Licensed Aviation mechanic
Old 04-21-2004, 07:08 PM
Re: Re: SES code P0141
Thanks Flatrater. Are there 2 O2 sensors after the cat in the 97. AcDelco has 2 different part# for the after cat O2 sensors. People at the parts store were not sure. How can I determine which I need. The two part#'s were Afs116 and Afs97 and both described as SENSOR,OXY(POSN 3). Also could the p0141 code because by a bad cat or only a bad O2 sensor?
Thanks again
fb
Old 04-21-2004, 07:24 PM
Flatrater's Avatar
Main GM Guy
Re: SES code P0141
As far as I know their are 2 different part numbers one for sensor one and one for sensor 2. The only difference between the 2 is the connector (the plug end).
Only only used the GM sensors, so I can't tell you anything about the aftermarket ones.
Your P0141 code means you have a bad heater circuit on your sensor. A bad cat will not cause this code to come on. Usually a bad cat will give you a P0420 code. I would just remove your sensor take it to the parts store and match up the sensor, taking a close look at the connector end. Yours should be more of a square connector (2 rows of 2 wires). The other O2 sensor has 4 wires right in a row side by side.
This is a bad!
XX
XX
as looking into the connector you will see the wires arranged like this.
XXXX
this is the other sensor looking the same way.
ASE Master Tech
ASE Advanced L1
GM Master tech
Old 04-21-2004, 07:32 PM
thanks again
