For those whos Bonnies are shuddering/stalling
Its seems that with most if you replace your spark wires this usually fixes your problem but if you are one of those whose is still having the problem I traced the problem in mine which might help you out. Before you go and replace your Ignition control module well let me state first that I have a 1990 SSE. The electrical wires that plug in at the bottom of your ICM might have a short which was the case with mine... it was the far left wire... mine was crimped and the contact was cutting in and out.... causing the engine to idle almost to a stall and kick back in. So play in that area and hope you solve your problem. Good luck
