Old 04-21-2004, 03:41 PM
ttyson ttyson is offline
dumping fuel???
I've changed the CPI Unit, Fuel pump, the EGR Valve, map sensor, coolant temperature sensor and control module. New timing chain. New plugs but it's still seems to be dumping fuel and fowling plugs out quickly. Any ideas what else to look for????
Old 04-21-2004, 05:24 PM
pcv pcv is offline
Did you scan the vehicle to check the sensor parameters? One of your sensor is out of spec causing the your "fuel dump". Scan the vehicle and let us know.
NOTHING LIKE AN OLD CAR.
Old 04-21-2004, 11:19 PM
dofunny dofunny is offline
Re: dumping fuel???
Hey PVC
I have a 92 Blazer with a 4.3 v6 vortec engine in it and it is dumping fuel in the oil.. After turning the engine when trying to start it up the engine locks up and I have to take out the plug. The plug are very wet with gas.Do that sound like a sensor as well.
[email protected]
Old 04-22-2004, 09:34 AM
Re: dumping fuel???
What do you mean when you say scan the vehicle? I've looked to see if any visible signs.
Old 04-23-2004, 04:57 PM
amac209 amac209 is offline
Send a message via MSN to amac209
Re: dumping fuel???
dofunny you have an injector problem. get a shop to clean them their not closing all the way. common problem with scpi
Old 04-26-2004, 11:09 PM
Re: dumping fuel???
Hey amac209
You may have a point. One of my injector line has turn white. Is that why it may run hot in traffic on a hot day also.
