Old 04-21-2004, 01:03 PM
ttyson ttyson is offline
Manifold Gasket & Oxygen Sensor????
What's the easiest way to check for a manifold gasket leak and also if an oxygen sensor was bad, shouldn't you get a code for this? I have a 1992 s-10 Blazer 4.3 vortec - v-6.
Old 04-22-2004, 11:23 PM
JWhite8055's Avatar
JWhite8055 JWhite8055 is offline
Re: Manifold Gasket & Oxygen Sensor????
an old trick is to use a can of starting fluid.
Start the motor and spray sparingly around the edges of the intake manifold, if you find a spot where the RMP increases when you spray, you've found a leak!
The O2 sensor sould set a code if it's bad.
If it ain't broke, fix it anyway.
Old 04-26-2004, 11:32 PM
Rowlin Rowlin is offline
ok
the starting fluid works but brake cleans works better on finding a leaking intake
but if its a bad o2 i wont always set a code off in the computer
the o2 can become lazy, this will cause no code but what it does is switch at a extrmely low speed but switch enough no to cause trouble u will notice bad gas milage or good depending where it get stuck the most
Old 04-27-2004, 08:47 AM
JWhite8055's Avatar
No doubt brake cleaner works, as would many higly combustable products, but most of them have no lubricant in it, starting fluid (most brands anyhow) does.
Old 04-27-2004, 11:14 AM
mikeyk22 mikeyk22 is offline
use carb and choke cleaner
