Old 04-21-2004, 01:03 PM
GTPSPEED GTPSPEED is offline
BOSTONjoe98gs
headers,install
i ordered some headers and i was woundering if its easy to put them on,cuz i heard it was ,and will they even give more horses or what,hope so,with the intake and catback im hoping it will improve throttle responce a little,but let me know,ps. i did search for this but couldn't find much
2000 GRAND PRIX GTP RED 14.345 @97.8mph
ubend delete
3in jimmyC downpipe
magnaflow high flow cat
Joeflo CIA (made it myself)
free bypass mod
3.4 pulley from zzp
Gates premium belt
1 step colder plugs
zzp PCM
ss 409 xl turbo mufflers
Old 04-21-2004, 02:21 PM
ashah000's Avatar
ashah000 ashah000 is offline
Send a message via AIM to ashah000
Re: headers,install
Open hood
Take off heat shield
Get WD-40 or Pbblaster and SOAK the bolts (8) on the header. The bolts (2) connecting the exhaust manifold and the flexpipe, and the bolts (2) connecting the flexpipe and the cat converter.
Then let it sit for at least an hour, I like to let it sit overnight (so do it the night before)
Unplug o2 sensor harness. LEAVE sensor on the pipe.
Take off the exhaust manifold.
Take off flexpipe. The bolts on the cat will be hard, put some muscle into it, or get a breaker bar and turn!
Once everthing is off. Take the o2 sensor out of the old pipe. You can loan an o2 sensor socket at autozone if needed.
Then put the o2 into the header, use antiseize around the threads. DO NOT get it on the sensor part.
Then put the header on and don't forget the gasket and use antiseize on the bolts/studs.
Put flexpipe on, can use antiseize if you want. Use a new gasket in between the cat and the flexpipe, if it did not come with one.
Make sure all bolts are tight.
Start her up and make sure there are no leaks.
I hope I did not miss anything
EDIT>> To make it easier have an extension. I just used 2 or 3 small extensions. Also I believe you will need a deep socket for one of them.
For Sale 98 Eclipse GS, 5 spd
Old 04-21-2004, 07:07 PM
BOSTONjoe98gs
Re: headers,install
cool,thanx ash,hey are they worth it,i mean will i be able to tell the difference
ubend delete
3in jimmyC downpipe
free bypass mod
3.4 pulley from zzp
Gates premium belt
1 step colder plugs
zzp PCM
