Old 04-21-2004, 11:40 AM
jacer jacer is offline
Send a message via AIM to jacer
Ecu Question??
Will A P28 Ecu Work For A B18c1?? Thanks
91 CRX HF -CONVERTED TO SI
88 DX TRANNy
A.C.T CLUTCH STAGE 2
SHORT SHIFTER
91 ZC SOHC HEAD P&P,MILLED WITH DELTA 272 CAM/
MSD IGNITION
PM6 CHIPPED ECU
PACESETTER HEADER
DROPZONE COILOVERS
ENKEI 17'S
97 INTEGRA SEATS
MANY MORE MODS COMING SOON...... brakes.....
Old 04-21-2004, 11:49 AM
4GZChatch's Avatar
4GZChatch 4GZChatch is offline
Send a message via AIM to 4GZChatch Send a message via MSN to 4GZChatch Send a message via Yahoo to 4GZChatch
Re: Ecu Question??
It will work from what I know, but the fuel maps would be so weak that you'd get crappy power and run lean. The P28 is for a 125hp 1.6L, which is a world away from the 180hp 1.8L you're trying to run with it...
Remember: You can't spell Crap without APC!
Classic SE-R
GTi-R turbo setup
3" DP
U12 modified ECU
Hyperco GenII suspension
Progress sway
SAFC
etc. etc.
Old 04-21-2004, 11:53 AM
travagliante's Avatar
travagliante travagliante is offline
Re: Ecu Question??
send the ecu to zydyne or another company and have it re-chipped
Old 04-21-2004, 12:55 PM
marked001's Avatar
marked001 marked001 is offline
Moderadur
Send a message via AIM to marked001
Re: Ecu Question??
hondata is who you'll want to deal with to get it remapped...not sure that zdyne deals with obd1 ecu's.
SOLD!
Old 04-21-2004, 04:00 PM
91civicDXdude's Avatar
Re: Ecu Question??
Uberdata, Crome, etc. etc.
www.pgmfi.org
a p28 is the most sought after obd1 ECU. you can use it with any engine, provided you use the correct maps
