Old 04-21-2004, 10:47 AM
zeebea zeebea is offline
keyless entry
I need the schematic for a 1998 tahoe lt 4x4 4door so I can figure out where the keyless entry heart is. Any ideas...
Old 04-21-2004, 03:58 PM
Kst8er Kst8er is offline
Send a message via AIM to Kst8er Send a message via Yahoo to Kst8er
I have a manual for 96 model. Should be identical. I will look this evening & get back with you tomorrow.
Old 04-22-2004, 07:28 AM
JD68 JD68 is offline
the wire for power unlock coming from the keyless entry module is white its on both sides and its a positive trigger
Old 04-22-2004, 08:39 PM
keyless entry
Thank you, now where is the keyless entry module located?
Old 07-08-2004, 02:02 PM
miller4 miller4 is offline
My 99 yukon is located under the driver side dash above the amp(amp is silver box just behind ashtray) the reciever for RKE is behind metal plate that amp is mounted to. Remove 1 screw, remove 1-15mm bolt and loosen the other 15mm bolt and slide plate and RKE module out.
Good luck.
