Go Back   Automotive Forums Car Chat > Engineering/ Technical > Forced Induction
Forced Induction Discuss topics relating to turbochargers, superchargers, and nitrous oxide systems.
Old 04-21-2004, 06:30 AM
JPNMATT JPNMATT is offline
Send a message via AIM to JPNMATT Send a message via Yahoo to JPNMATT
Question what do I need before the turbo?
I'm new in the car thing so I dont know too much about aftermarket. I live in Japan and I own a Honda civic SiR hatchback. I need to know what parts I need to buy before I buy and put on a turbo kit? I would ask people here but, no one speaks any english which makes me SOL. Good prices and Best parts are always good. So can anyone give me a push in the right direction?
Old 04-21-2004, 12:46 PM
ikou ikou is offline
Send a message via AIM to ikou
Re: what do I need before the turbo?
Good question J. i've been searching for the answer question too. later
Lance
Old 04-21-2004, 01:30 PM
GWInquisitor14's Avatar
GWInquisitor14 GWInquisitor14 is offline
Send a message via AIM to GWInquisitor14
What do you mean, what kind of parts do you need? Are you talking about parts other than the turbo or parts other than the turbo kit. What parts come with the turbo kit. Id susgest buying each part individually and not getting a kit, it will be worth it in the long run
If the car really knew about all this trickery, hed be pretty mad.
FOR SALE
2 10" Alpine 1041 Type R
JBL BP 1200.1 1200 watt RMS amp
Message me if you are interested, make me an offer
Old 04-21-2004, 04:10 PM
turbo2nr's Avatar
turbo2nr turbo2nr is offline
Send a message via AIM to turbo2nr
Re: Re: what do I need before the turbo?
supporting mods, bigger injectors, hi- flow fuel pump, adj, fuel pressur regulator, and inhanced ignition sys, msd maybe, fuel managment, like a standalone or a apex-i safc, copper spark plugs b/c they burn cooler on turbo cars, low-comp. head gasket, you mihgt want to put more agressive cams, re-build ur bottom end if you want to boost more then 8psi saftely, theres probably others but i cant think of them right now.. but make sue your tunning is right when you install the turbo of kiss ur motor goodby..
1
Shift_BOOST
97 s14
Old 04-21-2004, 09:42 PM
Yup he pretty much hit the nail on the head. Id go w/ the Hondata as it is better for tuning than the apexi safc
FOR SALE
Old 04-22-2004, 06:34 AM
i THINK i FOUND AN IMPORTANT THINGY?
i GOT AHOLD OF ONE OF MY FRIENDS BACK IN THE STATES AND HE SAID ITS ALL ABOUT A STROKER KIT ITS A MUST WHEN IT COMES TO UPGRADING TO A TURBO, BUT i THINK IM JUST GOING TO GO WITH A SUPERCHARGER FROM VORTECH LESS MONEY AND YOU DONT LOSE THAT MUCH POWER IT PUSHES OUT LIKE 7PSI NOT TOO SHABBY JUST HITTNG THAT UP.
Old 04-23-2004, 10:35 PM
Ya stroker kits are nice but u dont necessarily need one for a turbo. The supercharger should be nice, but w/ a turbo u could eventually run more boost and get more power
FOR SALE
Old 04-24-2004, 01:20 AM
DeleriousZ's Avatar
DeleriousZ DeleriousZ is offline
Send a message via MSN to DeleriousZ
i thought stroker kits made the engine way more unstable when boosting? i'd save up for the turbo man.. you'll be kicking yourself in the end if you don't
ZedEx Crew Member #6
1988 300zx turbo 5spd. 3" mandrel exhaust, filter, afco rad, e-fan, poly engine mounts, mbc at 8.5 psi, turboxs rfl-h bov, gutted plenum, etc.
blown turbo, under construction.. gt35 coming.
Old 04-25-2004, 01:46 PM
jajimo's Avatar
jajimo jajimo is offline
They don't speak English, but don't you speak Japanese? I mean, wouldn't that sort of be essential to living there?
Old 05-15-2004, 09:11 AM
vtec92civic vtec92civic is offline
Send a message via AIM to vtec92civic Send a message via MSN to vtec92civic Send a message via Yahoo to vtec92civic
boost it man . . . more potential in that I can help you put a kit together or get a cookie cutter kit (greddy, drag, revhard etc . . .)
Old 05-19-2004, 06:42 PM
Lightbulb
isnt it possible to run a turbo charger kit on only 7psi and get the psi up after you do internal work. I have heard that in several places just getting a full rounded opinion.
Old 05-19-2004, 07:31 PM
boosted331 boosted331 is offline
Re: i THINK i FOUND AN IMPORTANT THINGY?
1) Stroker kits are a waste of money for a turbo honda, period. I don't feel like going into it right now, but if you would like to try an argue your point in all caps, go ahead.
2) Vortech/Procharger centrifugal kits suck the big one on high revving small displacement cars. You get no low end kick because they make boost/power linearly with RPM's, and all around suck.
Old 05-19-2004, 11:37 PM
you can run 10psi safely on stock internals . . . I have even seen people run 12psi+ on stock internals. it's all based on how well your motor was maintained, or how your motors current state is as far as compression checking, and mainly your tuning. if you have really good tuning or a really good tuner that will get you very far in the boosted world.
