Old 04-20-2004, 08:39 PM
StvnRowe StvnRowe is offline
Problems with ABS light
I have a 2000 Grand Prix SE, and lately my ABS light and my traction control off light come on for no reason. I cant turn the traction control back on, and the problem seems to fix itself when I turn the car off and then back on. But it keeps re-occuring. To make maters worse, the brakes are pulsating every once in a while when I step on them. Any suggestions?
Old 04-20-2004, 09:21 PM
Brandon Budd Brandon Budd is offline
Send a message via AIM to Brandon Budd
Re: Problems with ABS light
i would say the pulsing is your rotors are warped and the ABS lights is the sensor on one or more of your tires is bad or somehow got unplugged/dirty like mine did when i had the same problem. I beleave you have to change the wheel hub sensor if its bad, someone correct me if I am wrong.
Old 04-21-2004, 12:31 AM
MoshimoGTP's Avatar
MoshimoGTP MoshimoGTP is offline
Send a message via MSN to MoshimoGTP
StvnRowe, first read this :
http://www.automotiveforums.com/vbul...&highlight=abs
this helps me... i hope this help you too!
RED 1999 Grand Am GT - RAM AIR V6 H.O., 4drs, sunroof, and more!
Old 04-22-2004, 10:31 AM
kilroypr's Avatar
kilroypr kilroypr is offline
Send a message via MSN to kilroypr Send a message via Yahoo to kilroypr
The reset trick would not harm you a bit and will cost you nothing. If that does not work then making sure no dirt on the connectors is the other way to go. The last thing is then replace the hubs
