Old 04-20-2004, 07:15 PM
Dr Juice Dr Juice is offline
Send a message via AIM to Dr Juice Send a message via MSN to Dr Juice
Upgrade spark plug wires?
What i wanna know is, if i add in preformace sparkplug wires on a stock ignition system with decent bosch plat 2 plugs, will there be a power gain, or anything nocicably different?
Old 04-20-2004, 09:02 PM
rubix777's Avatar
rubix777 rubix777 is offline
Send a message via AIM to rubix777
nope
Re: Upgrade spark plug wires?
will take that off the list then, Thanks
Old 04-20-2004, 09:47 PM
whtteg's Avatar
whtteg whtteg is offline
Send a message via AIM to whtteg
The bosch +2's will do no more than the regular platinum plugs.
Old 04-20-2004, 10:28 PM
Plastic_Fork's Avatar
Plastic_Fork Plastic_Fork is offline
I got new aftermarket plug wires because they were new, insulated better, and looked snazzy. 'Bout all you'll get out of them though.
1995 Honda CRX del Sol VTEC
Manufactured: Suzuka, Japan
Production Sequence #1269
Team Del Sol member #1131
HondaVision: Team Sol Forum - Home of Team Del Sol
Old 04-20-2004, 10:56 PM
SenseiAccord SenseiAccord is offline
Originally Posted by rubix777
nope
not necessarily. It all depends on how u old wires are. If it is all worn and cracking and really shows signs of age then u can get a small amount of gain. if ur wires are still fairly new then probably get like .5-1 hp gain on stock everything. anyway to me it is worth ur money because now days when u buy a performance part... u usually pay about $50 per hp gain. see what i mean jelly bean?
Old 04-21-2004, 06:21 AM
Well lets see, i have 3 fairly new wires and 1 old one. Yes i bought 4, but one of the rubber extension pieces broke off at the top of the valve cover, so i have 1 realy old one. Worst part of it is, i had to replace them cuase 1 of the old wires was shot, one of the ones im using now. if that makes any sence
Old 04-21-2004, 01:03 PM
rubix777's Avatar
Well, of course replacing something broken with a good one will give you back the power that was lost.
I bought some sparkplug wires that were pretty cheap and ended up falling apart. The part that fits snuggly onto the spark plug actually separated from the seal.
I went with the OEM wires from a honda dealer.
Old 04-23-2004, 03:08 PM
whtteg's Avatar
IMHO get either OEM honda wires or ACCEL wires, the accel wires are the closest thing to stock fit and quality I could find.
