Old 04-20-2004, 04:52 PM
HondaCivic4358's Avatar
HondaCivic4358 HondaCivic4358 is offline
Send a message via AIM to HondaCivic4358
question on ecu and vtec
My VTEC D16Z6 swap has been done for quite a while now, and she runs strong as i thought it would. my question now is how do i get the vtec hooked up. i am definitely doin it the right way and getten the D16Z6 ECU cuz i still have the stock ecu in my 89 rex si. now i have seen d16z6 "chips" on ebay. i would still have to buy the z6 ecu tho right? btw, where can i get a z6 ecu to hook the vtec up? and how much?
Old 04-20-2004, 05:04 PM
amy@af's Avatar
amy@af amy@af is offline
Traffic Directing Admin
Send a message via Skype™ to amy@af
Re: question on ecu and vtec
ecu will run anywhere from $150+. the easiest way to hook it up is with a conversion harness. you plug your stock harness into 1 end and the other end into the z6 (p28) ecu. those are i believe $175-ish shipped.
gimmine a minute and i'll be back with a pic of the conversion harness.
you can always try wiring it yourself...i don't have any links handy. hoever, i'm sure somebody will be here shortly who does
"hi! my name is Lady, and i'm a HONDA-holic"
..don't make me send Setanta over in his Waambulance to give you an aloe tissue for your sensitive nose!
*~ ~> USeR GUiDELiNeS*<~ ~*
I <3 the G Ride ~*~ I <3 OLD SKooL
Old 04-20-2004, 05:08 PM
amy@af's Avatar
Re: Re: question on ecu and vtec
the 8 taped wires you need to extend and run. i have a hard time remebering where they all go:
4 wires to o2 sensor
1 wire to vtec
1 wire to knock sensor
1 wire for check engine
1 wire i can never remember
8 wires
Old 05-04-2004, 08:21 PM
Im so confused! I still need to hook it up does anyone have any diagrams or good sites for this???
Old 05-05-2004, 06:51 AM
91civicDXdude's Avatar
rpm activated switch and chipped PM6
Old 05-06-2004, 03:11 PM
I thought that if you didnt have the right ecu for the right engine, it wouldnt work properly. it wouldnt adjust the right fuel and oil pressure in order to operate the vtec properly.
Old 05-06-2004, 08:18 PM
the ECU doesnt adjust oil pressure. it activates a solenoid.
If you chip your ECU, you can make a program that properly simulates any other ECU you want.
Old 05-07-2004, 06:14 PM
How would i go about doin this
Old 05-14-2004, 08:23 PM
OK, someone tell me if i am right. I want to get the Z6 ecu to activate the vtec, but in order to do that i will need to get like a universal wiring harness thingy, like Amy said? if so, where can i get one? and a cheap ecu?
Old 05-14-2004, 08:34 PM
91hbman 91hbman is offline
Send a message via Yahoo to 91hbman
ive seen stock ecu's on ebay. if your thinking of buying one of the "performance" chips off ebay just be careful. i bought one for my 95 civic and paid to have it put in and it didnt do diddly squat
Thanks for any of the help that anybody has offered. I try to do the same. And remember "It takes all kinds to make the world go round."
Old 05-17-2004, 07:50 PM
So, the wiring harness too? or just ecu? god i need a site to go to with diagrams and info.....
Old 05-19-2004, 04:41 PM
hello? anyone?
