Go Back   Automotive Forums Car Chat > Saturn > SC/SL/SW
Old 04-20-2004, 03:37 PM
95sljuan 95sljuan is offline
Send a message via AIM to 95sljuan
clutch always engaged?
it's like the clutch is always engaged, the car will start, and go into every gear fine while on, but when you take your foot off the clutch it's like you never did.. still will go into gear, still wont move, just rev's. upon visual inspection without pulling the tranny everything seems fine... is it the clutch? ive never seen this happen before...
thanks.
Old 04-20-2004, 06:30 PM
Mork Mork is offline
Re: clutch always engaged?
Either the clutch is wore out or something is causing the clutch not to engage. Possible sticking throwout bearing.
Old 04-20-2004, 07:55 PM
DR1947 DR1947 is offline
Another possibility along the lines of Mork's suggestion is the slave cylinder could be bound up in the extended position of if is it loose the shafts could be in a bind.
Old 04-21-2004, 09:23 AM
Skullmaster Skullmaster is offline
Send a message via ICQ to Skullmaster
Pop the hood and check your vacuum line. I Had mine wiggle off and lost the rubber tube from extreme amounts of bass
