HUD help
Does anyone know what could be wrong with my HUD?
There is no light coming up from the unit but I can hear the motor working when I use the up and down buttons. (1997 GTP) |
Re: HUD help
Do you have it dimmed all the way off?
GTPgirl
Black 1998 Camaro - currently driving Black 1999 Grand Prix GTP - burned March 2008 Plum Crazy 1970 Dodge Challenger - work in progress! |
Adjusting the dimmer does not help.
Re: HUD help
There are 2 circuits at least on the HUD. One for the motor(from the dash positioning switch) and the other that reads the input from the PCM to display whatever. If the car has not had any electrical problems lately I would install a Bud HUD and if it works your is dead.
My HUD went out and I was totally bummed, so I went looking for information on the HUD. I found the easiest fix. I forget the web site that gave me the information, but a guy who worked at Pontiac said that a lot of cars were coming in for repair on the HUD. They were charging an arm and a leg for a new unit. He finally noticed that the problem was the photoeye or photocell. The problem is the soder joints are cracked or loose. All you have to do is re-soder the photocell's pins. And that is it. Mine works fine now. Thank god.
If you have a problem with the HUD dimming then this can fix your problem.
1. Remove HUD from car. 2. Remove 4 Torix screws from top of HUD 3. Remove ribbon cable and small 2-wire cable from circuit board. 4. Remove circuit board. 5. On the board there is a small photocell, the problem is that the cell has a cold solder joint. The cell is a 1/3-inch Circle with a black square in the center. All you need to do is resolder the two legs. 6. Put everything back. I was unable to find a replacement cell at radio shack. Monday I will look at a Digikey catalog and try to find the part. The cell produces a small amount of voltage. The more light the more voltage. 0-.75 volts. Mt cell was working fine but the joint was loose. When the board heated up it lost the joint increased resistance to the point that the HUD lost the voltage reference.Hope this helps....~Larry~
Re: HUD help
yEAH , THIS IS THE GUY WITH THE LIFE SAVING INFO ON THE hud. Nice to see you here BIG L you will save a lot of people the time and money trying to figure this one out. Thanks for the detailed post with pictures. You are a life saver. Any more little hints or tricks ?
Re: Re: HUD help
Re: HUD help
hi guys i have a grand prix GTP 2000 and need guidelines how to remove the hud pod without braking it of course , need to replace the hud i got everythig already but lacking these guidelines, it might be very easy for you ! hope you can help me.
![]() Thanks |
Re: HUD help
Hi Gavilan! Welcome to AF!
I have never had to remove nor install an HUD in a vehicle before, so I cant be of much help. Although, it may be easier and less confusing if you just start your own thread regarding HUD removal and replacement.
-2000 Grand Prix GTP 170,000mi (daily driver) -2000 Olds Alero 100,000mi (soon to be DD with gas at $3.45/gal) -1997 Chev K1500 4x4 115,000mi (Natalie's truck [nans_grandprix]) AF "2.0" Community Guidelines Conservative Victory 2012!!! "I'll Keep my Guns, Freedom, and Money. You can Keep the Change!" ----->>>>> Did You Know? <<<<<----- |
Re: HUD help
Ok I will start the new thread!
thanks |
