| Let's get Technical! Discussion for hardcore in-depth motor heads! |
B20b turbo ?
Ok now when I get my honda I am going to want to swap in a new motor and if not right away then soon after turbo it. Now I am going to want some serious power out of this. My question is how much psi can the stock b20 block handle safely and how much HP would that bring in? Or if I sleeve the block and rebuild with new internals would that be a better route for the long run? Now if I do the rebuild it may take some time before I can put the turbo in. Is this worth it in the long run if want some big power to take out Camaros and vettes. Or is this possible on stock internals? I really want turbo but dont want to spend a fortune but I do want good safe power. And dont give me crap about "go do more reading" or "there is more to know about turbos than you know" cuz I do read about this stuff constantly I just want some facts about the b20 because they are relatively new to mod and I dont know much about them.
Re: B20b turbo ?
Swap to a GSR motor, throw some 9:1 JE's, eagle rods, and a block guard in the motor, a good EMS, a turbo kit, and have some fun. The B20's have thin sleeves (84MM bore vs. 81MM bore standard on other B-series motors) which makes them weaker to turbo on stock internals. You really don't need to get a B16/B18 block sleeved to make enough power to run with vettes and F-bodies, so why go through all of that by going with a B20?
no matter what motor you choose, you should always prepare for the most power, definatly do the internals before you boost, cuz it will save tons of headaches later in the game.
Name: Scott Stable Of Cars I have Owned: 1991 Honda CRX 1990 Oldsmobile Cutlass Supreme 2003 Honda Accord 1998 Chrysler Concorde 2007 Honda Civic 1997 Toyota Camry 1995 Saturn SC2 1996 Ford Taurus 1991 GMC Sierra 2002 Daewoo Leganza 1999 Dodge Ram 2007 Honda CR-V 2003 BMW 325i |
Re: Re: B20b turbo ?
ZedEx Crew Member #61988 300zx turbo 5spd. 3" mandrel exhaust, filter, afco rad, e-fan, poly engine mounts, mbc at 8.5 psi, turboxs rfl-h bov, gutted plenum, etc. blown turbo, under construction.. gt35 coming. |
Re: Re: Re: B20b turbo ?
Re: B20b turbo ?
he's most likely saying it because of the vtec head with 170hp. the ls only has 140 stock. but most people say it's a better motor to turbo because it already has low comp.
