Old 04-20-2004, 01:04 PM
Tfrench912 Tfrench912 is offline
Thumbs down 95 Blazer won't start..help
I have a 95 Chevy Blazer with 100+ thousand miles on it. I was driving down the road and it just stalled out. Come to find out the ECM fuse had blown. It started to blow the fuse on as soon as it got put in. First, a new fuel pump relay was put in, nothing. Next, I put a new oil pressure switch in it. It started right up and ran for a day and quit. It was blowing the ECM fuse again. Put another oil pressure switch in it thinking it was a bad one and nothing. Finally, I replaced the fuel pump and it started right up. Drove fine and died a few hours later.....It will try to start but won't turn over..
Old 04-20-2004, 01:31 PM
michelq michelq is offline
Re: 95 Blazer won't start..help
you mean the starter will not engage
Old 04-21-2004, 04:30 PM
timssail timssail is offline
Lightbulb Re: 95 Blazer won't start..help
Try the fuel pump relay switch. they go rather slowly untill they do not work at all. If there is one. Strange little trucks these are.
Old 04-22-2004, 06:28 PM
all2u all2u is offline
Question Re: Re: 95 Blazer won't start..help
I have a 94 chevy full size blazer sport 4x4 it took a wack on the right front and did still run. the wrecker service picked it up, because the driver was arrested, however when we went to get it, it would turn over but won't crank. We checked the plugs they are getting fire and the fuel is working properly. The oil is very gassy from trying to crank it. It just won't crank. Not sure about these so where should I go from here.
Old 04-22-2004, 06:29 PM
Old 04-22-2004, 07:03 PM
rlith's Avatar
rlith rlith is offline
Send a message via AIM to rlith Send a message via MSN to rlith
If the oil has gas in it, you've screwed the pooch... Sounds like one of your rings went... At this point once the gas hits the oil, your crank bearings will be toasted...
