Old 04-20-2004, 01:57 PM
intrigue2001 intrigue2001 is offline
Cool p0410 code
I have an olde intrigue 2001 with a p0410 service code. air injection failure. Does anyone have any idea which sensor is causing the problem. There is a sensor on the air filter box, and the maf sensor.
Thanks.
Old 04-20-2004, 11:53 PM
illinoiswronski illinoiswronski is offline
Re: p0410 code
The air injection system is an emissions control. Start by checking for a blown fuse as this is a common problem.
The sensor you are talking about in the air box is probably the IAT (intake air temp sensor).
Old 04-21-2004, 03:32 PM
Re: p0410 code
Thanks I will check it out
Old 04-22-2004, 07:41 AM
Thumbs up Re: p0410 code
You where correct the fuse was blown, this was a 50 amp fuse. If it blows again does this mean the air pump needs replacing or could it be the relay.
Thanks for your help
