Go Back   Automotive Forums Car Chat > Nissan > Nissan Cefiro | Nissan Maxima | Infiniti I30 | Infiniti I35
Nissan Cefiro | Nissan Maxima | Infiniti I30 | Infiniti I35 Excellent platform and the good ol' VQ30DE and VQ35DE engines.
Old 01-12-2002, 03:07 PM
bioslime bioslime is offline
Unhappy Cold Start Problems
My 97 Maxima has problems starting when the weather is cold. It cranks fine except to get it started I have to step on the gas. Any ideas as to what might be wrong?....I have a K&N air filter, would it be giving me problems.
Old 01-14-2002, 12:06 AM
bluman3 bluman3 is offline
first you might want to clean your throttle body using this link. www.motorvate.ca. you can also adjust your TPS. you will have to search on www.maxixma.org. good luck.:frog: :coolguy: :badass:
bluman3's MAXIMA
Old 01-14-2002, 12:50 AM
bobo_80 bobo_80 is offline
Exclamation
change ur air fiter.....!!!!!!!!!!........a must........!!!!!!!!!!!!!!!!!!!!!!
Old 01-18-2002, 08:49 PM
Mr Nismo Mr Nismo is offline
Send a message via AIM to Mr Nismo
Temperature sensor is another good thing to check. Good Luck!!
Old 02-03-2002, 03:54 AM
MaximaDriver MaximaDriver is offline
Banned
Send a message via ICQ to MaximaDriver Send a message via AIM to MaximaDriver
check your coolant temp sensor. throttle position sensor. maf, and lastly your spark plugs... it might just be its cold. thats all. two cranks is normal in winter
v70 awd starting problem hot and cold jonnylove V70 0 05-13-2010 05:04 AM
97 S10 Blazer Hard Cold Start Problem Pilot423 Problem Diagnosis 1 10-14-2009 03:01 PM
96 Skylark starting problem mlb55 Skylark 0 03-14-2009 01:13 PM
Cold start problem / cold engine is hesitating drdma Celica 7 10-03-2003 04:38 PM
