Go Back   Automotive Forums Car Chat > Ford > Contour
Old 04-20-2004, 06:28 AM
M34SPFLDMASS M34SPFLDMASS is offline
96 Contour Stalls when normal temp
I'm doing a favor for a needy person, complaint is car wont run, so, 2.5 auto. I check oil level - look at engine, everything seems ok, I turn ignition on, hear fuel pump buzz, car starts up normal, take it for test ride, car runs great, power - shifts thru gears, temp guage rises up, car stalls. turns over fine, will not start. I place extra spark plug into each cyls 1-4, nice spark on each igniton seems ok. still will not start.,
If i hold pedal to floor, car seems to run but on like 2 clyls.. or really flooding out big time. strong odor of gas. Let car sit for a while, starts right up, runs great, then dies.
Any suggestions? Thank you fonr reading this far. bob
Old 04-20-2004, 08:26 AM
Cont..
SORRY, but forgot to give history. Car was smoking when running, had been supposedly overfilled with oil, garage mech changed mass air flow sensor, changed oil. This problem only has been since garage mech serviced it. Lady, picked up car, SEL is on.
Old 04-23-2004, 09:31 AM
LOCATED Prob
I removed air cleaner assbly, and found the egr tube had rotted, in half,
that craeted the hot exhaust blowing against part of the wring harness,
which in turn melted it, or most of it.
I attempted to remove the egr tube from the catalyitic converter, and mushed up the threads on the cat. now I'm f@#$.
cut into the melted blob, seperated most of the wires, tonight i'll cut back and repair the wiring.
back to the cat egr tube,
any ideas?
Old 04-23-2004, 11:55 AM
beyondloadedSE's Avatar
beyondloadedSE beyondloadedSE is offline
AF Ford Contour-Advisor
Re: LOCATED Prob
any ideas?
If you need an exhaust egr assembly, I have a used one with 90K on it. Ill sell it to you for cheap.
"The CEG Nazi"
www.contour.org
1996 Ford Contour SE - Sold
3.0L V6 and Arizona Dyno Chip Turbo Kit
364 whp, 410 wtq @ 16 psi and only 4,700 rpms.
1999 Tropic Green SVT Contour - Bone stock and MINT
