Go Back   Automotive Forums Car Chat > Pontiac > Sunfire > General Discussions
Old 04-19-2004, 10:51 PM
singledaddy_20886 singledaddy_20886 is offline
poor mileage 2.2L
Started getting poor mileage last summer i've done a complete tune up and o2 sensor.Computor says it's running to specs. But today it started to sputter coming off the light and I think i smelled gas? CAN SOMEONE HELP ME?
Old 04-29-2004, 03:11 AM
slappy180 slappy180 is offline
Re: poor mileage 2.2L
them problems come with age of the car.If u feel froggie u can look around for a new engine
Old 05-02-2004, 05:32 PM
crazydriver7686 crazydriver7686 is offline
Send a message via AIM to crazydriver7686
do you smell it when you turn the heat on, if so its a rubber o ring on the gas line right around the intake on the left side, i had that problem it reeked!!!!1
Old 05-05-2004, 09:07 PM
noize1er noize1er is offline
wow
dude this happens alot with the sunfires. it took me a week to fix the problem. the fuel injectors have a small round rubber gasket on the bottom of them. they go bad.lol it will cause the car to smell like gas. usually through the air vents in the car or outside near the winsheild wipers. one more thing is it could be the throttle body gasket or if you will the manafold gasket. cheap if you can do it youre self
Old 05-12-2004, 06:08 PM
Slade901's Avatar
Slade901 Slade901 is offline
Banned
Check your fuel pressure regulator vacuum hose.
If the diaphragm inside the fuel pressure relator fails, it will allow to suck the fuel into the intake and causing it to run rich and extra fuels are not burned.
