Old 04-19-2004, 10:06 PM
MODaGA? MODaGA? is offline
Speakers...
i have a 99 ga se, all i really want to know is how the hell do i get the stock speakers out, on the 6x9's in back get as far as removing that plastic piece behing the seats, and on the speakers in the front doors how does that cover pop off? im sure it needs a bit of forc to pop off i just dont want to break it. also im looking for info on a supercharger, for my 2.4l four banger, does it really help that much and how much does it cost? also where the hell can i look at some, and im not talking about another link to more forums.....help!
Old 04-22-2004, 01:39 PM
shaunw shaunw is offline
Re: Speakers...
how do you replace the back speakers in a 2002 grand am
Old 04-22-2004, 06:53 PM
Markgase2000's Avatar
Markgase2000 Markgase2000 is offline
Send a message via Yahoo to Markgase2000
Re: Speakers...
Wow this is one of the most common questions in here as of late.
Pull both rear seat backings down to expose the trunk space. Theres a plastic gaurd on the upper threshold held on by simple plastic pull pins , use a screw driver or a trim panel tool to pop them out and remove the gaurd. Then the speaker shelf cover comes out by pushing up a bit and pulling out."on the 6x9's in back get as far as removing that plastic piece behing the seats, and on the speakers in the front doors how does that cover pop off? im sure it needs a bit of forc to pop off i just dont want to break it. " <----- it comes out gently and the pins are cheap but still reusable so when you pullem out pull straight out not crooked.
The 6x9's come out easily , no screws just two push tabs and tilt it out , unclip the wire harnesses dont touch the light bulb , unless you like 3rd degree burns lol. hope that helps out.
If its not clean CLEAN IT!!
If its not gleaming SHINER UP!!
If its not appealing BAG IT!!!
