Go Back   Automotive Forums Car Chat > Cadillac > Deville
Old 04-19-2004, 09:27 PM
xxEC1Dxx xxEC1Dxx is offline
Im New
hey everyone, im brand new here, i just got an 85 coupe deville, and i have to get a new alternator for it, but i dont want to do anything crazy with it yet until i know its ok, but i was wonderin if this thing will burn out...
Old 04-20-2004, 03:41 AM
korn-fed caddy korn-fed caddy is offline
Re: Im New
spend the money fix it then have fun. this procedure is pretty simple if you dont take care of this it will screw up the electrical system or just comp./ brain box
Old 04-24-2004, 08:53 PM
i8uiky i8uiky is offline
Re: Im New
if your battery is dead or weak charge it with a battery charger. this will take a big strain off of your alt.
Old 04-26-2004, 07:31 PM
gbelovskiy gbelovskiy is offline
It is only good to replace the broken (not properly working parts of your car. The car is not so new to replace the alternator just for fun, HOWEVER if you have problems with yuor battery (does not turn the starter) or if you have all electrical equipment turned on the battery is going dead, or if your lights (DASH BOARD) is going dim and then all over sudden light then very dim, like jumps -- you definately have a problem with your alternator. Also you can come to mechanics shop if you got any friends there and just to ask them to check the charge which is coming to the battery you might get an answer right there. I had a lot of De Vills from 1978 up to 1994 years and know these cars a little...
Good luck!
Greg.
Old 04-26-2004, 08:04 PM
Re: Im New
you asked "but i was wonderin if this thing will burn out..." the anser is yes an alternator can "burn out"
