Old 04-19-2004, 09:26 PM
rosshatch89 rosshatch89 is offline
Send a message via AIM to rosshatch89
answer my question please
ok so i didnt check here first but i changed my tranny fluid and i just used 80w90 yea everyone is sayiong to use regular motor oil so have i done any damage its been kinda hard to shift but not like grinding or anything
Old 04-19-2004, 09:36 PM
Hilikus Funkin's Avatar
Hilikus Funkin Hilikus Funkin is offline
Send a message via AIM to Hilikus Funkin
Re: answer my question please
no dude theres no damage, some dumbass did this to my tranny too (not that youre a dumbass), just drain it and use either 10w-30 or 10w-40. I recomend 10w-40. You lose alot of torque (well i did) with that 80w-90. After like a week change the oil again to make sure you get most of the 80w-90 out, if youre too worried about it.
1991 Honda Civic DX Sedan
Old 04-19-2004, 09:39 PM
I forgot to ask, why does everyone put 80w-90 in their trannys anyways, my friend bought one from the junkyard for his integra ls and it had 80w-90 in it too. My dad uses that stuff in his thunderbirds rear-end, which is what its supposed to be for.
Old 04-19-2004, 09:48 PM
EF You's Avatar
EF You EF You is offline
EF Life Giver
Send a message via AIM to EF You
because domestic car owners tell them to, and most mechanics are domestic car owners. what i find ridiculous is that modern domestic cars dont even use gear oil in their manual transmissions. camaros and firebirds use AUTOMATIC FLUID in theirs. so my guess is all these old timers who drove 60s/70s muscle cars tell everyone that manual trannys need gear oil.
BTW, the very best oil to use in a honda manual transmission is MTF from honda. i know it sounds foolish, but its better than anything else. i had a slight grind going into third on my S1 tranny, and i replaced the oil with 10w30. still there. then i tried synthetic, still there. then i tried Redline. still there. used honda MTF, and it disappeared. stuff isnt too expensive, but luckily i was working for acura at the time and got a case of it for employee prices.
over 10 grand in parts, and about 300 hours of labor, and i only spent 3k. and then Katrina filled it with mud.
Old 04-19-2004, 09:53 PM
i keep thinking of things to say hehe
before we changed the transmission fluid i couldnt spin shifting to 2nd, and if i was in say 3rd going 25 i could stomp it and it would take forever to get to 40 (where i usually shift to 4th when im tryin to get somewhere) now I get plenty more torque and my car doesnt feel like such a weakling compared to my friends' integras.
Old 04-19-2004, 09:55 PM
now i can spin when i shift from 1st to 2nd at 3000 rpms. all i gotta do is pop the clutch. definately get rid of that 80w-90 dude. Youre missing out on the pep that our cars have.
Old 04-19-2004, 09:59 PM
Re: Re: answer my question please
how can you tell if you have grinds on your gears anyways? I didnt know you could get rid them.
Old 04-19-2004, 10:11 PM
1PhatCX's Avatar
1PhatCX 1PhatCX is offline
ditto! i used the Honda MTF and it was the best thing i did. it has a couple special additivies in it apparently, (or so i was told)
i was wondering, can u add a little bit of 80w90 to it? would it make it not grind as much if u have a little bit of 80w90 mixed with honda mtf in there?
i dunno just an idea
Old 04-20-2004, 01:48 AM
kingpinn's Avatar
kingpinn kingpinn is offline
that is so sweat i have grind going in to 3rd and didnt no what to do thank you ......
Old 04-20-2004, 02:10 AM
EF You's Avatar
EF Life Giver
Re: Re: Re: answer my question please
if you shift with any power, and you notice its a little harder to put into third, or if you hear it make a ch-chunk sound, or a grrrrr sound, then your synchros are wearing out, and thats what the sound is. the synchros are made of brass, and the rest of the transmission innards are hardened steel. so they wear out.
the reason that MTF is better is because it has some additives, im assuming that these additives stick to the brass better and allow the shifts to slide easier.
BTW, dont quote me on anything, the transmission ASE tests are the only two i havent passed yet.......even though i have rebuilt a few trannys before
Old 04-20-2004, 07:24 AM
1PhatCX's Avatar
Re: Re: Re: Re: answer my question please
man, when i pulled apart my tranny i didnt see any brass syncros, everything looked like hardened steel?!?!?!
Old 04-20-2004, 12:26 PM
EF You's Avatar
EF Life Giver
most people wouldnt see it at first either. when looking at the gearset on the output shaft, theres going to be shift forks that are slipped over these steel rings. the shift forks move those steel rings onto different gears when you shift. the brass synchros are partially under the rings, and between the gears. when you shift, the synchro will get completely covered by the steel ring.
Old 04-20-2004, 12:39 PM
thanks alot but yea my boss said gear oil and him being a mechanic and into hot rods since the 50's i figured i might as well take his wordbut i think you guys cant drive too well if you cant scratch second cuz i do it all the time even with the shitty gear oil lol just kidding thats just technique but thanks for the advice i dont know what i'd do with out a message board like this
Old 04-20-2004, 12:41 PM
another quick question what can i do to stop my tranny from leaking oil cuz i've noticed a slight drip
Old 04-20-2004, 01:04 PM
EF You's Avatar
EF Life Giver
you can try an additive that will slow the leaks, but the only real fix is to seperate the two transmission case pieces and redo the hondabond gasket
