Old 04-19-2004, 09:18 PM
Privatebigandrew's Avatar
Privatebigandrew Privatebigandrew is offline
Send a message via AIM to Privatebigandrew Send a message via Yahoo to Privatebigandrew
Angry Oil Problems
Ok, my car is starting to piss me off. Here's the deal. I put mobil 1 in my car three oil changes ago. I changed it at 5000 miles the first time, no problems. the secind time i put it in i noticed i was loosing oil somewhere. i had to add about a quart b/t oil changes. The third time i put in Mobil 1 i had to put in almost 2 quarts in a 5,000 mile interval. So i decided that maybe my car had too many miles on it to be running synthetic oil and maybe it was leaking past my rings. I just changed my oil a week ago and put in castrol gtx high mileage formula. I had the level perfect when i checked it, i even rechecked it after it ran awhile to make up for the filter. Well today (a week from my oil change) i checked it to see how it was going, and it is almost a quart over the max mark. I think my damn engine is hording the oil away like a hamster and just trying to piss me off. No, but seriously, if anyone has any input it would help.
94' Del Sol VTEC (B16A3) SOLD.
Accel plug wires, NGK iridium IX plugs, AEM short ram intake, DC sports ceramic coated header (4-2-1), Airmass high flow cat ,Custom Magnaflow exhaust, Bosal Brospeed tips, Neuspeed short throw shifter, Tokico clutch master cylinder, Tokico clutch slave cylinder, Prothane complete kit bushings, Brembo front rotors, NR EL-Glo instrument gauges, CTR LSD trans with ITR final drive, Exedy chromoly flywheel, ACT HDSS clutch kit, Raxle axles.
Old 04-20-2004, 10:45 PM
Plastic_Fork's Avatar
Plastic_Fork Plastic_Fork is offline
Re: Oil Problems
Definately sounds odd. Might have blockage somewhere or leaky seals somewhere. When was the last time you checked your oil seals in the motor?
I know the front camshaft seal is notorious for leaking on B-series motors, but I doubt you'll loose that much. Head hasket or oil cap maybe? Notice any leaks coming out there? Maybe one of the main engine seals. How's the oil filter? New? Is it fitting right? What about spark plugs - are they fouled?
How many miles do you have on your car? I've got about 102k and I've been running synthetic without any problems so far. Your car's only a year older than mine.
Just some ideas.
1995 Honda CRX del Sol VTEC
Manufactured: Suzuka, Japan
Production Sequence #1269
Team Del Sol member #1131
HondaVision: Team Sol Forum - Home of Team Del Sol
Old 04-21-2004, 12:12 PM
Re: Oil Problems
Yeah, thats the weird thing. I don't have any leaks anywhere. Of course the cam seal leaks, thats a given for B series. But like you said its very minimal. Headgasket and eveything is up to date. Plugs are burning good. I even did a compression and leakdown test not long ago and they were both good. It gets me man.
Old 04-21-2004, 12:13 PM
Re: Oil Problems
oh yeah, its got 135,000 miles
Old 04-22-2004, 04:11 AM
Re: Oil Problems
I doubt it's burning oil. Have you checked the oil filer? Maybe it didn't seal correctly. Other than that, I'm out of ideas. Might be an internal issue.
As expensive as it might be, I'd have Honda look at it. As a side note, though, the dude who did my oil change at Honda last overfilled my car by about a quart. I had them drain a quart to even it out, and when I checked the oil level the next day or two it was back to being a half-quart over.
Maybe it's a Del Sol thing....?
Old 04-24-2004, 07:01 AM
Re: Oil Problems
Well, i am a technician at Acura, so i might ask some of the guys in the shop. My buddies got the same model and year as mine with 175,000 miles and runs mobil one with no problems. I'll figure it out as soon as i get some more time to take a closer look at it. I am about to rebuild the engine soon anyhow, but thanks for the help.
Old 04-25-2004, 02:44 AM
Re: Oil Problems
No sweat - sorry I wasn't more help than that. Keep us posted on what you find out though. I'm curious myself so would like to know for future reference.
Old 05-05-2004, 04:19 PM
Tranzlogic Tranzlogic is offline
Send a message via AIM to Tranzlogic
Re: Oil Problems
if it was just low i would say a leak..but it comming back up.. ? drop your oil pan bro..sounds like blockage..the baffle comes out right by the dip tube too so it would make sence..besdies whats 4.00 for a tube of black RTV to seal the oil pan back and 30 mins to drain teh oil and drop it ?? more than worth it to me, cause if it is a buildup then its better cought now before it blockes your return or something
