Old 04-19-2004, 09:11 PM
danowe danowe is offline
front spring makes noise when terning
when i tern the the weel wile it is mooving it makes noise
can you help
thanks
Old 04-20-2004, 06:17 AM
tman's Avatar
tman tman is offline
Pimpin' ain't easy
Send a message via AIM to tman
Re: front spring makes noise when terning
What are you? two? Use the spell check.
What sort of noise is it, a small groan is normal at slow speeds.
Old 04-20-2004, 09:58 AM
pcv pcv is offline
Yes, what kind of noise is it? Lots of possibilities here. If it is a knocking noise when turning, it is possible that the axel shaft boot is broken, water in boot and the joint is starting to make a cracking noise. If that is the noise, the whole axel will have to be replaced.
Good Luck.
NOTHING LIKE AN OLD CAR.
Old 10-08-2004, 11:16 PM
beeaatch beeaatch is offline
strut bearings may be bad,with car raised,turn wheel and observe struts,the bad bearing will pop and stick at the top of the strut
Old 10-09-2004, 07:28 PM
buickmastermind's Avatar
buickmastermind buickmastermind is offline
Also check and see if the power steering pump pulley is hitting up against the AC line. That only happens when the car is moving. If it is, CAREFULLY pull the line(s) away from the pulley
Forgot to say, there should be 1-2 inches of clearance. If not, BINGO, problem: Solved
