94 Lumina 3.1 v6 Engine
the car was runing fine up untill 2 weeks ago when it just stall out on. i try to start it back up and it did it stay on for about a few min's then stall back out so i hand it towed home. try to star it a again to see it it will do the same thing and it did so the same thing so i put new plugs ect. chang the fuel filter because i thought that was the problem but still its the same way so now i have no ideal what can it be can so one help me please and tell me what it might be or something i can do to stop this for happening
The Kid |
Re: Can some one help me Please
does it start up every time then just die regardless of throttle position? oil pressure switch comes to mind. the crankshaft position sensor fails quite often on these cars too. you should check the fuel pressure if it drops off right before it dies you know somethings killing the pump circuit(oil pressure switch) if pressure stays up it's probably the crank sensor, ignition module, ecm or a bad connection to one of these components. is your tank full? there might be excessive vacuum in the tank try loosening the cap. does it suck in air? if so you probably have a problem with the evap system.
good luck |
probably the ignition control module they so conviently placed behind the igntion coils on the front side off the motor
Re: Re: Can some one help me Please
The car starts right up some time then right when im in drive And About to Pull Off it just stalls out i Put New Plugs New Wire's New Filter's fuel Filter, Air Filter, i also have a PCV Valve i want to put on it But Don't Know Where It Go. If You Know Can You Tell Me. ? that will help me a little bit I Know Its Cover up By A Hose But Where is This hose is it under the Valve Cover the thing that have the number 3.1 on it ???
what Is The crank sensor, ??? what is the ignition module ??? How can i Check the fuel pressure ??? Can It Be The EGR Valve??? Or Fuel Injectors??? It Sound And Feel Like Its Not Gettin The Gas When I put my Feet On The Acceclerator
The Kid |
Scan with a OTC tool
unplug tcc solenoid see if it drives w/o it. if so then replace.
I think I am having the same problem with my lumina if you fix it let me know what you did [email protected]. does it run fine in reverse and park and nuetral?
