Go Back   Automotive Forums Car Chat > Chevrolet > General Discussion
Old 04-19-2004, 06:28 PM
booheck booheck is offline
Question keyless pad
Hey guys i have a 96 taurus and i didn't have a factory keyless remote
I had one installed the brand is code alarm(3 channel remote car starter
and keyless) is it possible to program those wireless keypads to this
keyless remote/remote start.
Please someone help!
Old 04-23-2004, 06:59 AM
spotco2 spotco2 is offline
Banned
Re: keyless pad
There is usually a black disarm button located under the dash area somewhere or on the drivers kick panel area. There ABSOLUTELY HAS TO BE ONE OF THESE somewhere attached to the vehicle. What you need to do is open the drivers door so the interior light of the vehicle is ON. Turn the key to the run position (As if the vehicle was running) and hold the disarm button down until you hear the alarm cycle. You will hear 3 chirps usually and the locks, if you have them attached will go up and down with the 3 chirps. While still holding the button down, press the first button on your remote, sometimes known as the arm button or upper left hand button. Once you press this button, the alarm should cycle if it programs. Then press the first button on the 2nd remote control and you should hear the alarm cycle. The alarm has 4 slots to program. So when you do the first remote, then the 2nd, please do the first remote then the 2nd again, so basically you are programming each remote 2 times. If you have a 4 button remote, you must press the first button, or upper left hand button, then the 3rd button or lower left hand button, then do this with the 2nd remote as well. Once this is done, let the button under the dash go, turn the key off and your done.
