Go Back   Automotive Forums Car Chat > Buick > Century
Old 04-19-2004, 03:36 PM
fahmynader fahmynader is offline
engine stops on idle
I have a 93 century 3.3V6 engine. Have just replaced the fuel pum. If I break suddenly, the engine chokes, gets very rough idle for few seconds, then either stalls and stops, or catch-up and hear the engine sound goes high again. Please advise.
Thank you
Old 04-20-2004, 09:44 AM
pcv pcv is offline
Was the fuel filter replaced when the fuel pump was replaced? I'd do that first. Possibly the reason why your first pump went.
NOTHING LIKE AN OLD CAR.
Old 04-23-2004, 01:12 PM
Re: engine stops on idle
I just changed the strainer. I just noticed that by adding Gaz the car dos not stop anymore on idle, even though it has somewhat a rough idle. The problem appears everytime the Gaz tank shows almost more than a quarter.
Old 04-23-2004, 03:07 PM
bignoisey bignoisey is offline
Maybe your fuel pickup is not reacing to the bottom of the tank for some reason. I'm not sure of the design or what the pump looks like. Does it have a tube of some kind going down to the bottom of the tank which may be bent or displaced??
Also, check your fuel pressure. The pump may be new, but is it a good one? Its probably OK (strainer/filter too) or the engine would stumble under heavy demand rather than at idle while stopping.
Old 05-19-2004, 10:13 PM
CUTLASS870 CUTLASS870 is offline
Try Replacing Crankshaft Position Sensor I had a problem like this originaly thought it was fuel pump but it ended up being the CRANKSHAFT POSISTION SENSOR.I hope this helps.
Old 05-24-2004, 12:07 PM
Thank you all very much.
It seems that as long as the fuel tank is at least 1/3 filled (as seen by gauge) the car runs fine. Unfortunately the fuel pump was changed by a mechanic. Yes it does have a tube going down to the bottom. I think it is very reasonable if it is theoretically displaced higher so that it can't reach the bottom of the tank.
I wll try Replacing Crankshaft Position Sensor too (have to look first what this is and where it is). But would this if broken work fine if the tank is filled?
Thanks again for your help. Appreciate it.
Old 05-25-2004, 01:20 PM
terraboy terraboy is offline
Send a message via AIM to terraboy
i have the same problem... I idle fine but hard turns or sudden braking on a low tank usually results in stalling. I just keep gas in the tank and drive. Usually if it starts doing that I know i need more gas.
I havent been able to stop the car from doing that, but it isnt a major thing so I just make sure the tank is filled. Not much else you could do without having to tear the damn car apart.
your not alone my friend =)
Old 05-26-2004, 06:38 PM
public's Avatar
public public is offline
I have a similar problem on a 1989 chevy. It has been this way since new. The problem is the sending unit for the gas gague. The repair was expensive so I just know that 1/8 tank means I am walking. :-) . I just keep gas in the tank and drive.
Old 05-28-2004, 01:24 AM
matt919's Avatar
matt919 matt919 is offline
Send a message via AIM to matt919
you really can't rely much on gas gauges on older cars. I have a 93 pontiac, and after i fill up, i get about 200 miles until its at 1/2 a tank, then another 20-30 before its on empty.. its all screwy
