Old 04-19-2004, 12:54 PM
tobyw tobyw is offline
Buzzing from dash?
Anyone else have a buzzing noise coming from the dash/console area when you accelerate? Doesn't do it when you just rev the motor, you have to be moving. Sounds a bit like a fart muffler on an import, but fairly quiet/muted. I can't seem to find anything loose?
2003 GMC Yukon SLT/Autoride 4x4, 5.3, Dark Charcoal Mettalic
Old 04-19-2004, 08:30 PM
andjh123 andjh123 is offline
Send a message via AIM to andjh123
Yeah I've got something like that, started noticing a little while after I got a 3 inch body lift installed. It does sound like a sort of muted buzzing and it comes from low and behind the dash. To me it sort of sounds like the valves cycling. Since everything is working fine mechanically, my current conclusion is that the noise is result of changing the position of the engine relative to the firewall (the body lift does this) which may alter the sound muffling design of this area. That's about all I've been able to come up with.
Have you put a lift on yours by chance?
Old 04-20-2004, 09:15 AM
Nope, bone stock... In driving it a little more and trying to find the damn noise, it seems as though it may be related to a VEEEEERY slight vibration that I feel in the steering wheel. I mean REALLY slight, but if you just barely wrap your fingertips around the wheel and accelerate from a dead stop (that's when you hear the buzzing), there is a vibration that seems to be in sync with the buzz. Perhaps something in the steering shaft or joints?
Old 04-20-2004, 12:14 PM
Well it's interesting that it only does that when accelerating. Perhaps you are driving around in 4wd??? How's your gas mileage these days?
Old 04-20-2004, 02:42 PM
Nope, definitely not that. I engaged 4wd on a dirt road nearby to see if it made any difference in the noise, and unfortunately it doesn't...
Old 06-18-2004, 11:15 AM
paramediclane paramediclane is offline
i had the same thing, i found it was the passenger dash speaker grill rattling. easy fix.
Old 06-27-2004, 07:46 PM
Lil Sonny Lil Sonny is offline
Re: Buzzing from dash?
Check to make sure you have enough power steering fluid. But, make sure you dont poor to much in.
Old 06-30-2004, 09:53 AM
bklenox bklenox is offline
i have 04 2wd tahoe making same buzzing noise. when i push up slightly on the steering wheel it gets better. any suggestions to what it may be???
