Go Back   Automotive Forums Car Chat > Mitsubishi > Galant
Old 04-19-2004, 11:44 AM
ani ani is offline
Transmission/Overdrive problem, Please help!
I have a 97 Galant with automatic transmission. If the overdrive is turned on, it shiftes to neutral around 35 Mph. If the O/D id turned off, it won't shift to 4th gear, it stays in 3rd and if I'm driving 60-65 Mph, the Rpm is at or over 4000.
I've just got the transmission fluid changed, it did not solve the problem.
The car has a high mileage, 103K.
What do you think? Does it worth to fix it? Knowing that my A/C compressor is broke too, and the timing belt needs to be replaced also.
I would appreciate any suggestions.
Thanks
Old 04-19-2004, 02:59 PM
jamiecreviston jamiecreviston is offline
Send a message via Yahoo to jamiecreviston
Unhappy
I am having the same problem with my O/D in my 1992 galant. Goes into neutral when i push the O/D button in. Have you found the problem yet?
Thanks
Old 04-20-2004, 11:15 PM
ani ani is offline
I have checked it out today, and it seems that it is an internal problem. They are going to take the transmission out and rebuild it. We'll see.
Old 04-21-2004, 06:50 PM
RexNfx400's Avatar
RexNfx400 RexNfx400 is offline
Its called the "end clutch" inside the transmission. Actually you can get to it by removing the side cover on the tranny. The seal likes to break, then burns up the clutches. Someone could possibly fix it in the car. If this was the actual problem.
Good luck
Old 04-22-2004, 06:41 AM
Thanks guy's this helps. Will begin by pulling off the cover and see how much a job it's gonna be....Thanks Alot!!!!!
Old 02-24-2005, 02:29 AM
xpedition xpedition is offline
Re: Transmission/Overdrive problem, Please help!
my 88 galant had the same problem, i got it fixed and it didn't cost 2 much, can't remember price, but i think it was somthing 2 do wth a switch (not da 1 u push)
Old 03-10-2005, 08:18 PM
loveflying loveflying is offline
Replacing O/D clutch under that cover should fix your problem. Make sure you put right fluid.
Old 06-17-2005, 11:41 AM
tekong tekong is offline
I got a same problam with my 97 galant 103K too ..jamiecreviston could you please tell me how much it cost when u fix it ?? and it that problams is recover now ?? thanks
Old 06-18-2005, 10:10 AM
replacing O/D clutch fixed my problem. Parts around $65 , make sure everything is very clean when you put together. Also flued is very important, get the one recommended by manfctr.
