Go Back   Automotive Forums Car Chat > Engineering/ Technical > Forced Induction
Forced Induction Discuss topics relating to turbochargers, superchargers, and nitrous oxide systems.
Old 04-19-2004, 08:11 AM
defman's Avatar
defman defman is offline
Question Zex nitrous kit?
I have a 94 civic cx with a jdm b16a swapped in it. I am planning to purchase a nitrous kit for it, I have heard among other racers that zex is the best system to use. My question is if i do purchase a zex kit or any other kit, should i use a wet or dry system? I am planning on using a 75 hp shot with a stock fuel system. Which kit would be safer?
Old 04-19-2004, 01:03 PM
BrokenLimits BrokenLimits is offline
Send a message via AIM to BrokenLimits
WET Always is safer. ZEX kit sounds like a great way to go for you because it uses a fuel management system which makes it hard to blow up your motor.
Brandon
Columbus, OH and Orlando, FL
2000 Civic Si with fully built LS VTEC
Old 04-19-2004, 06:10 PM
jajimo's Avatar
jajimo jajimo is offline
direct port = win!
Old 04-19-2004, 06:23 PM
boosted331 boosted331 is offline
Re: Zex nitrous kit?
Wet isn't always safer, heard of fuel puddling?
Old 04-19-2004, 09:08 PM
defman's Avatar
what effect does fuel puddleing have on the motor? does it blow the intake off?
I have ordered a wet kit as of today, any suggestions on where i could mount the nozzle to prevent fuel puddleing?
Old 04-20-2004, 01:19 PM
defman's Avatar
Does anyone know?
Old 04-20-2004, 03:42 PM
well after all the research I did on them, its less of a problem then blowing your motor.
I am going to assume fuel puddling is when fuel collects in the intake and causes a FIRE Back which is where it ignites it.
This is obviously something that can happen but I have never seen in all the times I sprayed on my Si.
A wet kit is safer for your motor then a dry shot.
Brandon
Old 04-27-2004, 02:32 AM
got v-tec?'s Avatar
got v-tec? got v-tec? is offline
in that case you just convinced me to get a dry kit.
Old 04-27-2004, 10:25 AM
What?
Brandon
