Go Back   Automotive Forums Car Chat > Honda > Prelude
Old 04-18-2004, 10:24 PM
GWInquisitor14's Avatar
GWInquisitor14 GWInquisitor14 is offline
Send a message via AIM to GWInquisitor14
H23 Vtec Conversion
Im thinking about doing a H23 vtec conversion in my prelude, but i have a few questions. Are the pistons in the Si model and Vtec model the same, like will they be able to withstand the same amount of abuse. Also, if i put the oil squirters on the block, will that get in the way of the longer stroked H22 block?
If the car really knew about all this trickery, hed be pretty mad.
FOR SALE
2 10" Alpine 1041 Type R
JBL BP 1200.1 1200 watt RMS amp
Message me if you are interested, make me an offer
Old 04-27-2004, 05:21 AM
93VtecLude 93VtecLude is offline
Send a message via AIM to 93VtecLude
Re: H23 Vtec Conversion
From what I've heard the frankenstein engine your describing is a bad investment the compression will screw you unless you get new pistons etc.
Old 04-27-2004, 10:34 AM
AcesHigh's Avatar
AcesHigh AcesHigh is offline
Prelude Guy
Send a message via AIM to AcesHigh
90% of the people who's done it claims it's unreliable. 10% of those who's done it says it is. The h23a bottom end can't take what the h22a head is capable of.
1993 Mazda Rx-7 Touring
Ricer Extraordinaire
Old 04-27-2004, 03:54 PM
well say i was put new pistons in, just pistons, would that work or do u think id need new rods. I know the crank will be able to hold it.
FOR SALE
Old 04-27-2004, 05:54 PM
Prelewd's Avatar
Prelewd Prelewd is offline
Send a message via AIM to Prelewd
Re: Re: H23 Vtec Conversion
You can't JUST put new pistons in. The cylindar walls consist of a sleeve called FRM, or "fiber-reinforced metal". Basically, this reduces the thickness of the sleeves, without sacrificing friction, so the engines can have a larger bore. The downfall of this is that they only work with honda factory pistons. Therefore, if you are upgrading pistons, it'd be a good idea to resleeve your block to avoid catastrophic engine failure due to your piston hitting your cylinder wall when the piston expands faster as it heats up.
Resleeving costs upwards of a grand, plus the price of new pistons. Have fun!
Soon..
Cars:
1990 Nissan 300zx Twin Turbo
1992 Honda Prelude Si 4WS H22a Swap - For Sale
1965 Chevrolet 1/2 Ton - 500ci Cadillac Cometh
1970 Datsun 240z - For Sale
1972 Datsun 240z - For Sale
1977 Datsun 280z - For Sale
1991 Infiniti Q45 - Engine Donor to 240z - Parting out the Rest
Sold Cars:
1976 Jaguar XJ-S - Rear end Donor to Chev Pickup
1971 Datsun 240z
1984 Civic 1500 Hatch
Old 04-27-2004, 08:14 PM
Ya but isn't the H22 also made of this same material? Cuz the bores are the same on each engine. Wouldnt the pistons be hitting the H22 also then when they expand
FOR SALE
Old 04-28-2004, 01:00 AM
Prelewd's Avatar
EDIT: I think I know what you mean. The factory honda pistons are able to handle the FRM.. I think they do this by a thin iron coat around the piston.
Soon..
Cars:
Sold Cars:
1971 Datsun 240z
Old 04-28-2004, 04:43 PM
Like okay, what i just really want to know is, what kinda differences in the bottom end of the H23 and H22 is there, like strength wise. I know theres a lesser compression cuz its got a longer stroke and maybe dif size pistons, not sure.
FOR SALE
Old 04-29-2004, 03:35 AM
prelude97 prelude97 is offline
More Tourqe Thats What Every One Tells Me 156 Lbs/ft Of Tourqe
"F.O.R.D = Fast-Only-Rolling-Down"
Old 04-29-2004, 12:44 PM
Prelewd's Avatar
I know the H22 crankshaft is better counter balanced than the H23..
Soon..
Cars:
Sold Cars:
1971 Datsun 240z
Old 04-29-2004, 01:28 PM
On a side note, i just wanna say props to Prelude97 cuz of his signature, my friend is obsessed w/ his ford probe and we have been argueing about it all day then me and him are reading ur post and i just cracked up at the signature.
Anyways, i didn't know they had different crankshafts in them. From this book that im reading on Honda engines, the blocks on both engines should be the same, strength wise. I know the open deck design is gonna be bad either way. I plan on upgrading the pistons and eventually sleeving the block. I want the prelude vtec but the Si was so much easier to find. I plan on turbo charging the car, money isn't that much of an issue.
FOR SALE
Old 04-29-2004, 04:02 PM
Prelewd's Avatar
4th gen blocks are closed deck.
You could always pin your open deck block anyway..
Soon..
Cars:
Sold Cars:
1971 Datsun 240z
Old 05-01-2004, 01:13 PM
fastassprelude fastassprelude is offline
i got the h22 head on my h23 what is my red line becuse the h23 red line at 6.5 and the h22 is at 7.5 and i put and the pro. chip
Old 05-03-2004, 12:22 PM
AcesHigh's Avatar
Prelude Guy
Your redline is determined by whatever ECU you have plugged in. I have no idea what this "pro. chip" is, but that may be the final determinant to your rev limiter.
Old 05-03-2004, 06:20 PM
I think he means reprogramed chip
FOR SALE
