Old 04-18-2004, 08:59 PM
violator6090 violator6090 is offline
Question 3.73 Odd problem?
So i got a 3.73 put in my 98 Trans Am. Everything is great except for one thing. when i drive for a long time (an hour or so) at high speeds(say 80 mph) which keeps the rpms around 3000, i have a noise problem which also smells real bad when i come to a stop after. It sounds like the gear is lose or somthing and it makes a weird sound on each rotation till i pick up speed to about 30 mph. However, if i leave it sit the next day it will be fine with no noise. Not until i make an hour or so trip again will it make the noise. What the hell is going on?
Old 04-19-2004, 03:07 AM
DarkblueTA's Avatar
DarkblueTA DarkblueTA is offline
Send a message via AIM to DarkblueTA
Re: 3.73 Odd problem?
Have you checked the fluid level in the rear end? are you sure they put limited slip fluid in it?(I can't remember what its called exactly). check the fluid level first.
DarkblueTA
GT70, FMIC, Alky-water injection, Hooker Cat back, 208/230 .549/.579 121LSA Cam, forged diamond pistons/eagle rods, LS6 block, Lakewood LCAs, BMR STB/PHRB/Sway Bars, poly torque arm bushing, Spec Stage 4i clutch, B&M Ripper Shifter, SLP Subframes, 60# injectors, KYB AGX shocks/struts, Moser 12 bolt(373 gears, 33 spline axles, posi, ta girdle/etc/etc/etc) and HPTuner kit
2007 Nissan Titan Daily Driver. 2* advance
Old 04-19-2004, 08:02 PM
how do i check the fluid level?
Old 04-19-2004, 08:51 PM
DarkblueTA's Avatar
Re: Re: 3.73 Odd problem?
passenger side of the pumpkin....near the top. Take a 3/8" rachet and take out the 'bolt'(don't know what to call it...you will see it when you get under the car). If you have any questions, PM me and I'll provide you with my cell# and I can talk you through it.
DarkblueTA
Old 04-19-2004, 11:11 PM
ok thank you, yea i drove again today and its actually startin to whine more. its not doing the problem of the bad sound and smell but its constantly whining. ill check the fluid or have a mechanic look at it
Old 04-21-2004, 12:35 AM
DarkblueTA's Avatar
if its starting to whine...I'd take it back to the place that did the gears..sounds like the 'alignment' of the gears is off a bit.
DarkblueTA
Old 04-21-2004, 11:51 AM
yea i am taking it back tomorrow, this mechanic has got to be a real jackass
Old 04-21-2004, 01:03 PM
DarkblueTA's Avatar
You do know that you have to have a 'break-in' period for gears..right? don't get on it for the first 300-400 miles....just to make sure everything seat's well
DarkblueTA
Old 04-21-2004, 02:38 PM
haha too late for that
Old 04-21-2004, 02:39 PM
no 1 told me not to get on it and i have. but still if u heard how bad this thing is whining you would be pissed too
