Go Back   Automotive Forums Car Chat > Dodge > Dakota
Old 04-18-2004, 08:44 PM
Lunchybox Lunchybox is offline
i need stereo help
i have a '99 dakota sport, reg. cab, and i have sony 10" subs, a dual 460 watt amp, and a rockford fosgate cap, im just wondering if i need the cap at all? the subs run at 300 watts, and the amp is 460. i wasnt sure if the cap is really needed at all?
Old 05-04-2004, 07:52 AM
dan1as77 dan1as77 is offline
Send a message via AIM to dan1as77
Re: i need stereo help
you will get by just fine without it. do your subs run at 300 watts rms or is that the peak wattage? also, if you are running a sony amp, you will not get 460 watts out of it (that is rating is probably only if you bridge it into a 4 ohm load). you can probably plan on getting a good 175 watts to each sub with it, which is about what you will want if they peak at 300 watts, which is the way sony rates their subs.
