Old 04-18-2004, 07:53 PM
stang_racer20's Avatar
stang_racer20 stang_racer20 is offline
Send a message via Yahoo to stang_racer20
TB Hole
I just recently recieved my new TB, an Accufab 75mm, and I noticed I does not have a hole drilled in the throttle plate for extra air at idle. Is it supposed to be like this or are you supposed to create your own if needed?
92 Mustang GT, 347 Stroker(Forged Steel Crank/Rods-Balanced, Forged Alum Dished Pistons), B50 Block, Track Heat Intake, Twisted Wedge Heads w/ Stage 3 port/polish, 80mm C&L MAF, FMS 30# Inj., BBK AFPR, Trick Flow Stage 2 Cam, Trick Flow 1.6R Rockers, BBK EL-CC Headers, MAC O.R. H-Pipe, Flowmaster Cat-Back, Accufab 75mm TB, MAC CAI, BBK Pulleys, Griffin Alum Radiator, Mark 8 Fan, MSD Pro-Billet Distributor; AOD, Dynamic 3300 L-U Converter, B&M Trans Cooler; 3:73 gears.
Old 04-19-2004, 09:28 AM
HiFlow5 0's Avatar
HiFlow5 0 HiFlow5 0 is offline
Stanger
Send a message via AIM to HiFlow5 0
Re: TB Hole
From what I remember some TB's have them, and others don't. Your idle will be controled by the IAC attached to the TB. If there is still problem with idle, after you have everything set up, TPS and throttle adjusted , then I might try and adding a small hole in the butterfly, or pick up an idle air adjuster that goes between the TB and IAC. I have that and it helped out a lot.
[size=1]-1950 Ford Custom, flathead V8
-2013 Ford Flex
-1999 Ford F150
Old 04-22-2004, 09:41 PM
price111 price111 is offline
Re: TB Hole
My experience was that the throttle plate would "stick" without the hole. I had an Edlebrock 65 mm TB with no hole and the vacuum seemed to hold it until it broke loose and would rev higher than I wanted. Drilled the hole in the butterfly and no more problems. Guess Ford knows what's best?
My experience, anyway.
Old 05-02-2004, 01:26 PM
djsommer djsommer is offline
Re: TB Hole
I have an Accufab 65mm and my idle was strange too (part of it is the cam) but I bought an IAC adjuster from Latemodel Restoration Supply (www.50resto.com) part #LRS-9939-A for about 20 bucks and it improved the idle quite a bit. Don't drill a hole in the blade!! It'll only decrease the value of it when you want to sell it.
Old 05-02-2004, 02:02 PM
Ive seen it too. How exactly is it adjustable though?
Old 05-03-2004, 03:23 AM
Re: TB Hole
It's adjustable and allows a small stream of air into the intake which can then help solve idle problems.
