Old 04-18-2004, 07:52 PM
-= c a m a r o =- -= c a m a r o =- is offline
Send a message via AIM to -= c a m a r o =-
stroke or bore?
what gives an engine high-end power, stroke or bore? if an engine has a small stroke and a big bore, does it create more power at a higher rpm? are there any drawbacks?
"A silly Civic Si owner who confidently revs on an LS-1 powered Camaro at a light, cocky in the fact that his engine makes more power per liter, is going to get swatted like a pesky little fly, VTEC or no VTEC." - Mike Kojima, Sport Compact Car Magazine
Old 04-18-2004, 08:28 PM
89IROC&RS's Avatar
89IROC&RS 89IROC&RS is offline
Re: stroke or bore?
high rpm and horsepower is a large bore and short stroke, low rpm and torque is long stroke, small bore. think of it as piston speed, with a small stroke the piston travels less distance, longer bore the piston has far more travel, meaning more work. not a big deal for torque, where the added stroke gives added leverage and torque, but makes it harder to spin at high speeds. larger bore means more surface area for the combustion to press upon, meaning more hp. shorter stroke means less work. hope that helps.
Chevrolet Camaro - I enjoy beating the hell out of people
http://www.automotiveforums.com/vbulletin/showthread.php?t=68052
Old 04-18-2004, 08:29 PM
4onFloor's Avatar
4onFloor 4onFloor is offline
i'm just gonna guess and say that the bore gives it better high end power. just because generally the longer the stroke the lower it red lines
Old 04-18-2004, 08:31 PM
HURRICANE103 HURRICANE103 is offline
Re: stroke or bore?
Increasing the bore will not build more RPMs but more power within the original RPM range, (power band). Stroking a motor will build more torque and more HP but lower the RPMs, because you're increasing piston travel. By destroking a motor, (decreasing piston travel) and increasing the bore, lets say bring it back to it's original cubes, will raise the max torque to a higher RPM inturn increasing your H.P.
On the street the stroked motor is the ticket but on the strip horse power is king. Inorder to make HP you have to turn big RPMs.
There's alot more to building any style motor than just strokin it or finding a bigger hole.
Old 04-18-2004, 09:09 PM
Chevyracincamaro's Avatar
Chevyracincamaro Chevyracincamaro is offline
Re: stroke or bore?
haha...finding a bigger hole
Old 04-18-2004, 09:13 PM
89IROC&RS's Avatar
Re: stroke or bore?
lol not a problem for me thats why i drive a fast car lmao
Old 04-18-2004, 09:15 PM
Re: stroke or bore?
zing!!!
