2000 silverado u-joint problem
Hello, newbie to the site.
I've got a 2000 siverado with the u-joint squealing pretty bad. Is there a trick to taking this thing out, took off the rear straps and went to slide the driveshaft forward, nothing. Any help would be appreciated. Thanks! |
Re: 2000 silverado u-joint problem
If its anything like the 89-98 years, there are 2 plastic pins that hold the u-joint in the driveshaft. What I did to remove them was heat it w/a torch and then pressed the u-joint out w/a vice or hydraulic press.
1998 ECSB Z71
Whelen LED's Kenwood 2-way "BIG 3" 2500+ watt audio ![]() |
can't even get the driveshaft out
Yea, my u-joint has the round clips to hold it into the driveshaft. The problem I'm having is just getting the driveshaft off of the rear end.
if you have unbolted the straps, stick a pry bar between the center of the cross, and the pinion nut, and gently pry forward or back to rock the u joint out of the yoke.
use wd-40 or pb blaster and then "tap" the joint with a hammer. Excesive force can damage the pinion bearing so be careful.
pry bar.
I tried the pry bar on the cross. Didn't budge. I'm really starting to get ticked off at this thing. I've never spent so much time on a u-joint in my life.
The drive shaft should slide forward in the transfer case right? I need about a half and inch to clear the rear yoke. Thanks for all the help. |
Hmm...can you move the driveshaft at all??? Sounds like the slip yoke isn't..slipping? Also, this might sound crazy, but I've had to put my truck in Neutral, and set the park-brake to give it some extra play to get it out.
1998 ECSB Z71
Re: Re: 2000 silverado u-joint problem
Sudzyguy |
