Go Back   Automotive Forums Car Chat > Isuzu > Trooper | SLX | Bighorn | Wizard
Old 04-18-2004, 03:37 PM
uniqueuserid uniqueuserid is offline
Question 15k maintenance.
Hello.
Could someone please tell me where the drain plug is on the front differential on a 2001 Trooper? I tried three lowermost bolts (12 mm heads) on the rear of the housing and didn’t get any oil out.
Another question: how many pumps does it take to lube the propeller and u-joins?
I don’t want to end up with unnecessary mess and carrying additional weight of the grease might heart the performance
Appreciate your help.
Old 04-19-2004, 11:08 PM
2eyefishclaw's Avatar
2eyefishclaw 2eyefishclaw is offline
Send a message via AIM to 2eyefishclaw Send a message via Yahoo to 2eyefishclaw
Re: 15k maintenance.
no drain plug on front diff.
on the grease issue just stop as it is begining to come out of the joints
Old 04-20-2004, 10:51 AM
Thank you.
I found a drain for the front diff. One of the lower bolts that hold the case together.
The oil did not come out the first time I removed that bolt, because the hole was blocked by the gasket sealant.
As far as u-joints, I just don’t want to damage any seals if present.
Thanks again.
Alec
