Old 04-18-2004, 03:17 PM
LauBen LauBen is offline
Send a message via MSN to LauBen
Detailed Info on B16A2 engine
Ok here is a challenge for you all I need to know some very detailed info on the B16A2 engine, to put into a software programme called Dyno2003 it takes all your engine info and show what your BHP is and by changing setup you can see what effect mods will have
Now the problem is I need to know some very detailed information, I need to know;
* Intake Lift at valve in Inches
* Exhaust Lift at Valve in Inches
* Lifter Acceleration Rate
I also need to know valve opening/closing based on Set-
To-Seat like
* Primary Timing IVO
* Primary Timing IVC
* Primary Timing EVO
* Primary Timing EVC
* Intake Duration
* Exhaust Duration
* Intake Centreline Angle
* Exhaust Centreline Angle
* Lobe Centreline Angle
* Valve Overlap
I also need to know about;
* Bore
* Stroke
* Intake Valve Dia
* Exhaust Valve Dia
So if any one is up to a challenge and able to provide any or all of the info I need then let me know
Thanks a lot
Old 04-21-2004, 11:03 AM
Darc Tangent Darc Tangent is offline
Re: Detailed Info on B16A2 engine
Hey try:
http://www.raceseek.com/honda_specs.htm
http://www.crower.com/cat/import/honda/camshafts.shtml
http://www.jdmuniverse.com/forums/ht...=Engine%20Info
They have some of the info you're looking for. Good luck!
Old 05-05-2004, 04:37 PM
Tranzlogic Tranzlogic is offline
Send a message via AIM to Tranzlogic
okay this thread has been up for a min so i dont even know if your gonna read this but...
thats alot of info for us to explain when a simple web search can tell you more than you could ever want to know...
second that program is only going to give you theoretacle hp and tq gains..its a mathmatical solution that the computer gets from basic match and physics...not what your actually working with ! you wanna know what your working with then spend the money and run a dyno ! thats what we all do !! even my drunk slack bitch ass can set down with you and with a calculator and basic engine and technology class logic can come up with hypothetical gain theories !! waste of time and money to me
