Go Back   Automotive Forums Car Chat > Volkswagen > Passat
Old 04-18-2004, 01:32 AM
mindtwizzter mindtwizzter is offline
Send a message via AIM to mindtwizzter
Unhappy abs/brake light comes on ?????
i have a 98 gls 1.8t and sometimes when i first start the car up the abs/brake light will come on..sometimes it wont,it will come on later down the road and then sometimes shut back off????i have no clue about this problem.if anyone could help me out with some info id appreciate it thanks
Old 04-18-2004, 01:04 PM
boschmann boschmann is offline
Re: abs/brake light comes on ?????
You will have to have the system scanned with a VAG scanner or simulator like VAG-COM.
Old 04-18-2004, 01:06 PM
do i have to go to the dealership for that???
Old 04-19-2004, 10:00 PM
Not if you can find a shop that has the right equipment. A generic OBD-II scanner will not be able to read the ABS codes.
Old 10-28-2004, 11:21 AM
ksm1213 ksm1213 is offline
Re: Re: abs/brake light comes on ?????
Hi,
i hv same problem since front tyres are changed; had the scan saying "power failure " , what should be done next ? can anyone tell me ?
thanks
Old 10-30-2004, 06:51 AM
SunShineRules SunShineRules is offline
Hello everyone - I joined this forum because I am trying to find the answer to the same question.
I have a 1999 VW Passat in Atlanta, GA with 79,000 miles on it.
I had my front tires changed this week and ever since, the "ASR" triangular light keeps flickering. It flickers most of the time when I am going around sharper than normal corners.
Thanks!
Old 10-08-2005, 01:59 AM
lodownlv lodownlv is offline
Send a message via AIM to lodownlv Send a message via Yahoo to lodownlv
i can fix them.
