Old 04-18-2004, 01:00 AM
Macdaddy4738 Macdaddy4738 is offline
Send a message via AIM to Macdaddy4738
Painting Chrome parts?
how do i go about painting an already chromed part?? it seems like the paint wont stick to that too well...
Old 04-18-2004, 01:18 AM
supermod04's Avatar
supermod04 supermod04 is offline
Banned
Send a message via AIM to supermod04 Send a message via MSN to supermod04
Re: Painting Chrome parts?
take some 300 grit or so sand paper and sand it down just remove the chrome, primer and paint
Old 04-18-2004, 01:26 AM
RallyRaider's Avatar
Zomby Woof
If you want to strip the chrome off entiely just soak it in some bleach overnight. The chrome will come right off, leaving just a clear coat on the plastic that the manufacturers use to bond the chrome to the part. That can be reomved with any of the usual suspects for removing paint.
If you just want to detail paint a section of a chromed part then there shouldn't be too much of a problem.
Old 04-18-2004, 01:49 AM
well it came with chrome rims...i may repaint them im not sure depends on what color i decide on. There are some chrome parts for the engine that need to be painted...but its only like a part of that piece
what do i do then?
Old 04-18-2004, 01:57 AM
Zomby Woof
In that case, if you are worried then scuff up the area to give the paint something to grip to.
Old 04-18-2004, 03:12 AM
TanKaBoY's Avatar
TanKaBoY TanKaBoY is offline
could u just primar it without sanding it?
Completed:
Sexy Iwase Kyoko's FD3S RX-7
Apexi D1 FD3S RX-7
Old 04-18-2004, 03:33 AM
Jumpman_Z's Avatar
Jumpman_Z Jumpman_Z is offline
Send a message via AIM to Jumpman_Z
For painting chrome parts, I use only clear or metallic paints. Yeah, they don't stick all that well either, but they look better. To make things easier, I like to place a little paint on a sheet of paper, let it sit for a couple minutes so that it begins to cure a little, then use a brush to apply it to the chrome part. The paint is a lot stickier then, so it's easier to apply it. You may have to do it to or three times to cover the whole part , just give it a few more minutes between coats.
Oh, this works great if you're trying to give your part that "powdercoated" look. It's fairly easy to do, I got it right on my first try. However, I would suggest trying it on a piece of chrome parts tree first, just to make sure you get the look you're going for (especially if you're going to try this on a set of wheels). I think clear acrylic paints and Testors metallic paints work the best. This technique works on chrome foil and chrome painted parts, too.
My 200th post, yaaaaaaaaaaaaaay!
Air 23 - News, release dates, info, tons of pics, and much more!!
Air Jordans
Air Jordan release dates
Z33, 287 hp, 274 lb/ft torque. 'Nuff said.
Old 04-18-2004, 03:56 AM
Zomby Woof
Old 04-18-2004, 04:05 AM
criptix's Avatar
criptix criptix is offline
hmmm never used the bleach method ( hate bleach ) i usally scrape it off with an exacto
Old 04-18-2004, 07:51 AM
935k3's Avatar
935k3 935k3 is offline
You have to remove the chrome and the clear coat underneath. Some paints will react with the clearcoat if not removed. Use oven cleaner and the chrome and clear coat will be removed in 5-10 min., rinse thoroughly and you are ready to paint.
Old 04-18-2004, 03:02 PM
Jumpman_Z's Avatar
Re: Re: Painting Chrome parts?
Originally Posted by RallyRaider
What does that mean? I've been on this forum about 8 months longer that you. I just have better things to do than be a post whore.
Air Jordans
Old 04-18-2004, 04:43 PM
Zomby Woof
Re: Re: Re: Painting Chrome parts?
Who you calling a whore! Just having some fun with ya! Besides you are the one concerned with your post count.
Okay now we are post whoring! And I'm using way to many smilies.
Old 04-18-2004, 05:40 PM
Jumpman_Z's Avatar
Ok, sorry about that. I didn't mean to make it sound like I was calling you a whore, I was just saying that I don't post that much, but I'm not a newbie.
Air Jordans
