Old 04-18-2004, 12:54 AM
supermod04's Avatar
supermod04 supermod04 is offline
Banned
Send a message via AIM to supermod04 Send a message via MSN to supermod04
Clear coat eating decals?
I clear coated my seat after i added my decals and it started to eat the decals, i even did a test on a old piece of decal and it was fine. i am very worried about doing my final decals on my car and then clear and have them ruined!? i did a few tests on scrap cars and it was ok, but still i am worried!? should i clear then add decals?
Old 04-18-2004, 01:20 AM
RallyRaider's Avatar
Zomby Woof
Re: Clear coat eating decals?
Clear coating lacquer over decals is always a bit of a risk. To aviod any heartbreak make sure the decals are well seated and totaly dry, any airbubbles must be removed or the lacquer will damage them. When painting always mist your coats and leave about 15 minutes between them. NEVER succumb to the urge to lay down a thick coat otherwise the solvents will do nasty things to the decals.
If in doubt don't bother with a clear coat over the decals, a gentle waxing will suffice to protect them. It's only when you want to do things like change the reflectance or remove the ridges of decals and masking jobs that you will want to use a clear coat.
Old 04-18-2004, 01:23 AM
supermod04's Avatar
Banned
ok cool. i have enamal clear and enamal paints so i dont know what went wrong. i might just not even clear coat it, i will do some more work with it, maybe add some decals to a old body and clear and do some experiments
Old 04-18-2004, 01:30 AM
Zomby Woof
Enamels eating decals? That is a new one on me. Were you using some kind of "hot" solvent to thin it?
Yes, doing some testing is alway wise. Also be aware that different brands of decal are affected in different ways as well.
Old 04-18-2004, 01:35 AM
supermod04's Avatar
Banned
i used duplicolor enamal clear, and i have some revell decals. but i think i figured out the problem
my seat was flat white, and it is some cheapo crap, and i did the decals, and then added a clear and it like just ate 1 of the decals
but i have always used duplicolor grey primer, and testors paint when i airbrush and duplicolor clear and it has been fine. must have been the cheapo flat white paint!?
i will do some more tests!
Old 04-18-2004, 03:54 AM
Bas Carwash's Avatar
Bas Carwash Bas Carwash is offline
I know the problem. I screwed up a complete body of a Toyota Corolla WRC full of decals with the clear coat. I found out 2 options: Use Micro Set and Micro Sol on your decals. Second: Don't use Tamiya clear coat, but use the Humbrol version. Gives you the same shine after waxing, but never eats your decals.
Good luck!!!
Old 04-18-2004, 07:44 AM
935k3's Avatar
935k3 935k3 is offline
Were you using glos over seats? If so why? Interiors should be flat for the most part. Try airbrushing Testor's Dullcote for interiors. I am afraid to gloss over the body decals, that is why I wax and use Future and I get pretty nice looking shiny cars. The trick is to polish or wax the decals so they are shiny before applying Future. I do not spray Future I wipe it on.
Old 04-18-2004, 09:16 AM
mike@af's Avatar
mike@af mike@af is offline
Captain Over Engineer
Thats what I was wondering. Why are you clearcoating the seats in the first place? Also, you should try using Microsol to set the decals.
-Mike
Old 04-18-2004, 09:54 AM
supermod04's Avatar
Banned
o i added a light coat over the it for protection, but it never made it glossy. it stayed the same flat white. why i dont know but o well.
Old 04-18-2004, 05:07 PM
Zomby Woof
I always clear coat seats. But I start with a gloss coat for applying decals, they work better on a smooth surface. On a rough matt surface you risk "silvering". When that is done I finish with a matt/flat coat. Simple.
Old 04-18-2004, 05:15 PM
supermod04's Avatar
Banned
well the instructions said gloss white seat, and some other gloss white stuff and i just followed the directions
