Go Back   Automotive Forums Car Chat > Oldsmobile > Cutlass Series
Cutlass Series Includes Cutlass Ciera, Cutlass Cruiser, Cutlass Calais, Cutlass Supreme, Custom Cruiser, as well as the GM N-Body subforums.
Old 04-17-2004, 10:54 PM
punkcats punkcats is offline
Cannot locate Turn Signal Flasher in '93 Olds Cutlass Ciera
Unable to locate the Turn Signal Flasher in my 93 Cutlass Ciera. I've looked under the dash, the floor, pedals, etc but can't find it.
I really miss my turn signals and you can be cited for non-working signals in Calif.
please help!
Old 04-18-2004, 01:50 PM
michelq michelq is offline
Re: Cannot locate Turn Signal Flasher in '93 Olds Cutlass Ciera
flasher behind ashtray
Old 04-18-2004, 06:56 PM
Re: Re: Cannot locate Turn Signal Flasher in '93 Olds Cutlass Ciera
Michelq; thanks for replying. Forgive me for asking..but could you be more specific? When looking behind the ashtray, there is nothing that resembles the (aluminum) flasher. Is there anything which would block it from view? Perhaps a panel or part under the dash that needs to be removed to get to the flasher?
Please help if you can..I just spend good money on a repair manual with less than I know..not to mention insulted by the sales guy at the auto parts store ("move the stick on the steering column up/down sweetie")
Crazy that I can clean and change the MAF but can't find the flasher under the dash!
Thanks again,
punkcats
Old 04-19-2004, 04:38 AM
you need to pull ashtray ,is realy hard to sea it right on the side of it
Old 04-19-2004, 10:50 PM
michelq,
Mission Accomplished! It took removing most of the dash, then putting on the hazards and feeling for the "click" vibration and presto! it's behind the fuse panel in the glove compartment. Just removed the glove compartment housing and felt around and there it was!
Thanks
punkcats
Old 04-20-2004, 04:57 AM
punkcats
thank you for posting the fix
