Old 04-17-2004, 07:46 PM
schneidey schneidey is offline
ESI talon owners please read i need help within 4 hours please help!!!
i have the 98 talon ESi and i need to know the oil capacity and the way to check the tranny oil because im seein oil leakin around the crossmember and bellhousing as i had to repalce the tranny once already and i need to make it home can someone please tell me how to check the level of the tranny oil
thanks alot
Old 04-17-2004, 09:32 PM
coldhell9 coldhell9 is offline
Re: ESI talon owners please read i need help within 4 hours please help!!!
Have you tried your owners manual? All of your oil capacities will be in there. you will also only have two dipstick tubes in your engine compartment. One of them will obviously be for your trans. sorry i couldn't be more of a help and good luck.
Old 04-19-2004, 08:53 AM
1stGenRocks's Avatar
1stGenRocks 1stGenRocks is offline
Send a message via AIM to 1stGenRocks
you check your tranny fluid by starting the car shifting it through each gear (P,R,N,D,L) then leaving it idleing in park you pop your hood go outside to the front of the car look for the probably red dipstick handle pull it if it says what tranny fluid to use on the side of the stick then you got the right one, wipe it off stick it back in then pull it and check the level remeber that your tranny isnt hot yet
-1stGenRocks-
95 Tsi AWD: 6 bolt, DSMLink, 880's, ACT 2600, lightweight flywheel, AGX's, Dropzone springs, poly motor mounts and suspension bushings, 3 inch turboback, gus modded 1g BOV, hardpipes, drilled & slotted rotors, 17's
plans: bastard 20g, water/meth injection NO FMIC
