Old 04-17-2004, 06:52 PM
zerotolerenz zerotolerenz is offline
Question 2.3 Fuel issues needing resolved
I have a 1988 Mustang 2.3 4cyl engine. I am not sure, but possibly my low battery power could be the problem, seeing as I have an electric fuel pump. I use a good bit of fuel injector cleaner, so I know that clogged fuel injectors probably aren't the problem. About a year ago, my car just died, acting as if I had run out of gas, but I just filled it up. I waited a couple of days, left it sitting where it broke down, and I changed the fuel filter. It started right back up with no problem. 6 months later, the same thing happened, but I changed the fuel filter immediately, but it still would not start. I left it there for 2 days, and it started up like nothing happened. Now, I was informed that it was the fuel pump, but if the fuel pump went out, then would it not start back at all? Also, my fuel guage quit working correctly around the time that this had first happened; it will go all the way to the full mark when I rev it up. Also, sometimes when I pump gas, the nozzle will act as if I had a full tank, you know, "click" or what not. Could all of these issues contain the same problem? They say that it will cost me over $300 to replace the fuel pump, because it is in my tank. I dont want to pay that kind of money if it is not the fuel pump, and they want $30-$60 to check my fuel system to find the problem. I am not sure if it is the catalitic converter, but there is a hole the size of a silver dollar an inch before it. The acceleration has always sucked somewhat unless it is warmed up for about 15 or so minutes, even in the summer. It is not the transmission fluid. What could the problem be?
Old 04-17-2004, 11:32 PM
StangNut86 StangNut86 is offline
Send a message via AIM to StangNut86 Send a message via Yahoo to StangNut86
fuel pump. they're cheap. the work to install one is fairly easy, too, especially in ponycars like stangs and camaros.
if you have a mechanically-inclined friend, have him do the work for you and save major $$.
-Andy
'89 Mustang 5.0 - How fast? i'll know this weekend.
'86 Mustang LX - Shortblock is built, now for the rest of it.
"Put the subject before the verb, hmm? Fail this class, you will."
-Yoda teaches english class.
