Old 04-17-2004, 08:17 AM
sammuts sammuts is offline
How do you know what fuse you need for an amp?
Hi,
I am trying to connect a Magnat 620 4Channel amplifer on a Peugeot 205 Gld and I would like to know what fuse I need from the battery. Is there a way to calculate this or what ?
Old 04-17-2004, 08:25 AM
Haibane's Avatar
Haibane Haibane is offline
Send a message via AIM to Haibane
Re: How do you know what fuse you need for an amp?
If you are using the 4 channel amplifer to power speakers I would assume you are getting 620 rms total? I would say run 8 guage wire with a 50amp fuse, which is generally what 8 guage kits come with that I have had.
www.cloudcity.deviantart.com
Old 04-17-2004, 08:55 AM
PaulD PaulD is offline
Audio Guy
Send a message via AIM to PaulD Send a message via Yahoo to PaulD
if you know the ACTUAL power output ....... you can divide the total RMS of all channels by 12 (volts) and multiply by 2. However, you must understand that the fuse is not to protect the amp - it is to protect the CAR (or the car's battery/ alternator)
Old 04-17-2004, 03:06 PM
sr20de4evr's Avatar
sr20de4evr sr20de4evr is offline
Yeah, the fuse is matched to the size of the wire used, NOT the draw of the amp (well, you have to make sure the fuse is large enough so the normal draw doesn't blow it, but beyond that you don't look at the amp's draw at all).
'01 Black Sentra SE
Weapon-R intake, HS header, HKS catback, ES motor mounts, B&M short shifter, Tein coilovers
Alpine 9835, Adire Koda 6.1, Adire Brahma 15, Arc 2100cxl, Linear Power 2.2hv, Cadence ZRS-8
'05 Silver WRX STi
Injen SES Downpipe, HKS Carbon-Ti catback, Cobb Stage 2 Tune, TiC Super Shifter, TiC Klunk Killer, Tein springs, Nitto NT555R Drag Radials
