Old 04-17-2004, 12:01 AM
Tanked Tanked is offline
Installing a Short Ram, '89 CRX Si
Hey, few questions here...
First off, this is pretty basic, but I got an eBay short ram system for my CRX. The only mounting hardware was an "L" bracket. How does this attach? I had a thing rigged up, but it obviously wasn't right (I had to bend the bracket) and the filter popped off after a few miles of driving.
Secondly, if I had a ZC, D16Z6, D16Y8, B16, or B18A installed - could I use the same intake I would currently use?
Thanks.
2003 Civic EX 4D
D17A2 (Stock)
5-Speed Manual
Old 04-17-2004, 12:11 AM
91lxdreamer's Avatar
91lxdreamer 91lxdreamer is offline
Send a message via AIM to 91lxdreamer
L bracket? What company sold you the intake bro? My ebay intake didnt come with any brackets, mine just sits in there, and you have to screw the filter down with a clamp...can you take pics to show whats goin on? Also, I dont see why you couldnt use the same intake...I could be wrong, but then again, I dont know the placement of your engine and battery right now, so it might not....but take pics and I can probably better help you.
Official AF Primer Crew!
Updated 1-23-05
For sale: Stock 4-door corner lights. 13" stock wheels with 6 month old tires.
Old 04-18-2004, 01:33 PM
BullShifter's Avatar
Re: Installing a Short Ram, '89 CRX Si
The "L" brackets probablt attaches the instake to the inner fender, just like the stock air intake did. My iceman attaches like that.
Old 04-21-2004, 08:35 PM
Yeah, pictures really would help. My brother has the car right now though
I had my intake loose without any brackets for a while, but it was pushing against my front-right lowbeam headlight and seemed wrong...
2003 Civic EX 4D
D17A2 (Stock)
5-Speed Manual
Old 04-21-2004, 08:37 PM
Here's basically what I bought, although the filter looks slightly different:
http://cgi.ebay.com/ebaymotors/ws/eB...category=38634
2003 Civic EX 4D
D17A2 (Stock)
5-Speed Manual
Old 04-21-2004, 09:48 PM
hilltopper hilltopper is offline
What i pritty much did with mine is from the clamp that holds on the air filter, i fitted the little L bracket to.(pritty much put it in there and tighten it down) Then bending the other bracket, one end should bolt up to the L bracket, then the other end to one of the holes that you can bend the flat bracket to connect to. Tighten everything down and give it a try...I bet there is another way to do it a little better but this should get ya going.
Old 04-21-2004, 10:32 PM
kingpinn's Avatar
kingpinn kingpinn is offline
this mite not be any help. but with my aem short ram i just let it hang its fine, put the filter on tight real tight and let it hang. it should hold and every week or so just look at it it should do just fine....
Old 04-21-2004, 11:33 PM
Yeah I let mine hang too, I just tighten everything up nice and tight. Never had a problem
Updated 1-23-05
