Old 04-16-2004, 10:49 PM
BlackShadowTSi BlackShadowTSi is offline
Send a message via AIM to BlackShadowTSi Send a message via MSN to BlackShadowTSi Send a message via Yahoo to BlackShadowTSi
Question About the Ruber that goes around the windows...
I'm going to paint my car prety soonm i allready choose the color, but I want to make a good job, so after I paint the car I will like to put all new ruber or if someone know about some kind of product that I can use to make the looks better let me know (I'm talkin about the rubber who goes in the windows, sunroof, etc.) Cause it looks prety bad.
Thanks in advance.
Diego Fontán
Eclipse GS-t ==>AWD
12.12 @ 113.xxmph
60' 1.76
Check My GS-T ==> AWD project
car's video: http://cssteam.com/gstx.wmv
At the track: http://videos.streetfire.net/video/aad4c670-6066-44d5-b6f6-c04346cb8407.htm
Old 04-19-2004, 06:01 AM
amdsoldier amdsoldier is offline
bump I'd like the know the same
Old 04-19-2004, 08:38 AM
slowgsowner slowgsowner is offline
if its the weatherstriping your talking about then
1. if it's not in bad shape (doesn't leak) then don't replace it,
if it's just faded, make sure you tape it up well ( start from under it then wrap it around, remove it if possible, you getbetter paint jobs this way) then either use some, bear with me, baby oil, this soaks in and shines it.
I have done this several times and it works just try it, just make sure you spread it on kinda thick
2. if it is bad then check out jc whitney, they usually carry vehicle specific weather striping. much cheaper than mitsubishi part houses
if your talking about the hard plastic trim, then just take it off, scuff it up and spray it with trim paint (semi gloss black, flat black) or do like some shady body shops do. get a rag dip it in brake fluid and wipe them down without touching the paint (I strongly recommend AGAINST this)
best of luck
