Old 04-16-2004, 09:23 PM
01 Bowtie 01 Bowtie is offline
Question Fuel Filter
Gentlemen, I have a 2001 Silverado Ex-Cab Sportside 4x4 w/ the 5.3L engine and it's time to change the fuel filter. As I don't have a service manuel yet, can anyone tell me where the filter is located.Thanks!
Old 04-17-2004, 01:49 AM
buttnekked buttnekked is offline
Re: Fuel Filter
goto autozone.com they have a component locator feature as part of the website. Most likely it's on the frame under the cab but they can tell you for sure.
Old 04-17-2004, 09:14 PM
amac209 amac209 is offline
Send a message via MSN to amac209
Re: Fuel Filter
it's in the drivers side frame rail a little behind the drivers door. you need a 16mm and 13/16" or 21mm wrench to change it. it's recomended that you depressurise the fuel line by removing the fuel pump fuse while the engines running and allowing it to die. i usually don't bother with this only a little bit of fuel leaks out.
Old 04-18-2004, 06:20 PM
jeverett's Avatar
jeverett jeverett is offline
Send a message via ICQ to jeverett Send a message via AIM to jeverett Send a message via MSN to jeverett Send a message via Yahoo to jeverett
Re: Fuel Filter
A bit of info for you. When hooking the lines back to the filter, be sure the o-rings are in place. One of mine slipped out and caused gas to leak.
1998 ECSB Z71
Whelen LED's
Kenwood 2-way
"BIG 3"
2500+ watt audio
