Go Back   Automotive Forums Car Chat > Honda > Integra
Old 04-16-2004, 07:59 PM
integrasedan integrasedan is offline
Radiator Fan, is this normal?
there's two fans on the radiator.
#1 fan near the radiator hoses/passenger side, turns on at a certain temp. It also turns on when the A/C is turned on.
#2 fan near the driver side seems to never turn on anymore. I used to see it turn on at the same time as the #1 fan.
My question is the #2 fan to cool the transsmision oil in the radiator or both coolant?
Does the #2 fan have a higher degree temp than #1 fan? maybe that's why I don't see it turn on?
Also what could be wrong, if there is really a problem?
Old 04-19-2004, 06:32 PM
IntegraB16 IntegraB16 is offline
Re: Radiator Fan, is this normal?
2 fans huh? My car only has one fan. But then again I don't have A/C. I would say if your fan use to come on but don't come on anymore there could be something wrong with it. If it is bugging you then check it out and if you want you could wire it to the other fan so it comes on at the same time.
Old 06-10-2004, 01:40 PM
91q45a 91q45a is offline
It may have a faulty relay(located along-side the radiator on the driver-side i believe), or the fan itslef may be bad. I had a problem with the fan-timer keeping my fan on too long, until the battery died, but atleast it came on, so yours is not getting power, or is burned out.
Old 06-11-2004, 01:41 AM
sameintheend01's Avatar
sameintheend01 sameintheend01 is offline
Send a message via AIM to sameintheend01
are your temps running high?
Clear Corners
Front and Rear Strut Bars
Cold Air Intake with K&N filter
Iridium Spark Plugs
High Performance Plug Wires
High Flow Cat (unistalled)
Cool high/low beam lights
All around slotted and AEM pads
Old 06-11-2004, 01:51 AM
AcAttackGS AcAttackGS is offline
Send a message via AIM to AcAttackGS
1st fan is the radiator fan...the 2nd is for the A/C...to see if ur fan is bad pull off the sensor and jump it...i thought mine were bad because engine was get to bout halfway point on temp gauge and they took a while to kick in...but i guess thats what its supposed to do....jump it see if its the actutal fan tho...if not then check temp sensor.
for mods go to my webpage...
Old 06-11-2004, 01:55 PM
my engine temps normal, so i'm not really worried about it anymore. i'll have it checked out eventually. so far the a/c fan still doesn't turn on, just the radiator fan, even with the a/c on.
thank you for all advice everyone
