Go Back   Automotive Forums Car Chat > Hyundai > Tiburon | Tuscani
Old 04-16-2004, 05:23 PM
Tiburon99 Tiburon99 is offline
Nitrous shot
I was just wondering what is the highest volume shot of nitrous that a stock tib can handle?
Old 04-17-2004, 04:55 PM
nisco nisco is offline
Tib Guy
Send a message via AIM to nisco Send a message via MSN to nisco
Re: Nitrous shot
depends on the engine and the mofds and such.....
Old 04-18-2004, 10:06 PM
tibby01 tibby01 is offline
reliably?
i woulnt go over a 50 shot. how often are you going to be giving your car the laughing gas?
Old 04-24-2004, 07:33 PM
Partizan's Avatar
Partizan Partizan is offline
Re: Nitrous shot
50-shot max on stock bottom end. But even then you can't be squeezing it off every straight away. I mean you could get away with a 75 or 100-shot of Nitrous once or twice but it'll wear your engine and do it too many more times and it won't be pretty. I typically recommend adding nitrous later on once you've beefed up the engine.
Old 04-27-2004, 11:17 PM
scottsee scottsee is offline
Send a message via AIM to scottsee
Re: Nitrous shot
the theory is 20shot per cylender Max. im not sure what the compession is on these tiburons but the higher the compression the less shot you should probably use, unless you have some good internals, and a solid ass gasket
Old 04-29-2004, 10:40 AM
the gasket wouldnt be the problem. the stock headgasket will hold to 600 hp. if you break it, ill paypal you 5 dollars.
beta 1's have a 10.3 C/R. 60 might be to much.
Old 04-29-2004, 01:50 PM
Tib Guy
Re: Nitrous shot
on which engine?... both or v6 or i-4?
Old 04-29-2004, 02:56 PM
Re: Nitrous shot
V6 setup
Old 04-29-2004, 05:12 PM
sbr7y sbr7y is offline
Re: Nitrous shot
if you do it right unlike most NOS idiots and use a custom fully wet system instead of direct port injection you wont burn any holes in your pistons and can push a 100 shot all day long that is if you do it right
Old 04-29-2004, 05:58 PM
Tib Guy
Re: Nitrous shot
theres a tib in fl that will be 200whp maybe alil more n/a v6 runnin a 150 shot... not sure on wet or dry
Old 04-29-2004, 06:29 PM
Re: Nitrous shot
on your stock engien if you use more then 75shot i think you'll be sorry. everything i've read has given the rule of 20shot per cylender MAX. unless your running lower copression, and have upgraded internals.
